![]() | Home > General (L405) > New L405 Owner: Advice on Premium diesel needed |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Hi,
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I haven't read my manual then because I haven't seen that!
I have looked at the online Owner's Handbook. It says this:
All diesel sold in the UK has to meet the EN590 standard so normal diesel should be fine. |
Thank you EM, you're a star.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Who sells the premium diesel then? My local Esso garage and pretty well others I use only have 1 diesel option, i.e. each pump has an Unleaded, Super Unleaded and Diesel nozzle? I'm used to the RON rating for unleaded fuels but haven't seen a pump with 2 diesel nozzles to give me a cheap/more expensive choice. Steve
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
They all sell both most places i fill up sir... Only usually small family owned outfits that don’t bother these days? Could that be why? |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Esso do a supreme diesel but the proper ones that are a different manufacturing process are BP Ultimate and Shell V Power Nitro
charly, this past thread on premium/ branded fuel versus supermarket fuel might be of some interest to you.
Thanks PLD.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
I'm still unconvinced on this one - maybe I'm not sensitive enough.
Cheers Craig - strange , I'll check around the pumps when I put some in tomorrow, unless one of the pumps has different diesel to the others as at both the main places I go to (Esso and Tesco), there is only 1 diesel nozzle on each side of each of the pumps . There's also a BP garage a bit further away, so I may check that. Or maybe it really is 'grim up North!' |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
Whenever possible I use Shell V Power or BP Ultimate super diesel, partly on the basis of "only the best for my baby" and partly because on the 4.4 petrol I found that I got noticeably better mpg and performance with their super unleaded, especially the Shell. On one occasion travelling up the A9 I had the "current mpg" display on the screen before and after filling up at a filling station that had only ordinary petrol. With the same speeds set on the cruise control the mpg was a fair bit lower after filling up than before, when the tank contained only Shell V Power. I have rarely used ordinary diesel, but when I have (Mull and Wester Ross) I found that the tank seemed to empty more quickly than usual, though stop-start driving on single track roads may have contributed to this. My RR handbook recommends that "high grade" fuel be used when towing, which also suggests that better fuel will make a difference.
I second the benefit in the 4.4, it makes a difference. |
I used to fill up the petrol 4.2 SC with Shell V Power Nitro+ every time.
