Home > Technical (L322) > 2002 td6 starting/running problems
Cmgrob
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Right here goes, my td6 is starting to annoy me.
Sometimes it will start on the bottom, most of the time it's endless cranking with it not starting. However if I put my recovery spec boost pack onto it, it still cranks a while but starts. Note it does really crank over any faster with the boost pack on, cranks over just fine without.
Once it's running will keep going all day long, no smoking or anything, pulls lovely then half hour down the road, it's pouring black smoke out making cars behind invisible, sometimes feels like it's misfiring n juddering on boost but fine cruising.
I have had fuel injection warning on the dash and read these codes.
Egr is blanked off
Any ideas people
Post #335143 29th Jun 2015 6:17pm
Cmgrob
Anyone??
Post #335287 30th Jun 2015 3:24pm
William97841
Have you checked to see if your inline secondary pump under rear passenger ache is working??
They normally go.
Post #335298 30th Jun 2015 4:09pm
William97841
Also do a leak off test on the injectors had the first and end one go causing it not to start
Post #335299 30th Jun 2015 4:11pm
When did you last change the fuel filter?
Post #335304 30th Jun 2015 4:45pm
