Home > Technical (L322) > 2002 td6 starting/running problems |
Cmgrob Member Since: 29 Mar 2015 Location: Northampton Posts: 7 |
Anyone?? |
30th Jun 2015 3:24pm |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 |
Have you checked to see if your inline secondary pump under rear passenger ache is working??
30th Jun 2015 4:09pm |
Also do a leak off test on the injectors had the first and end one go causing it not to start |
30th Jun 2015 4:11pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
When did you last change the fuel filter? |
30th Jun 2015 4:45pm |
