Home > My Range Rover > EDF - Mrs Edfors' shopping cart
Page 8 of 12 <123 ... 789 101112>
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
EDF had to do some use with one of the trailers.
And then take the trailer through MOT as well. Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #325193 30th Apr 2015 7:48pm
Edfors
@Riverstick, its used to test future products. So dash, mirrors and other things are getting replaced with new electronic gizmsos. The normal thing I pull around is this 40 ft trailer. We use it to measure and monitor different angles and views for the cameras which will be on future trucks to replace mirrors.
EDF have now let us down for the first time. The starter have stopped working, just getting the loud click. So I guess it's time to order a new starter. I've also tried with fully charged battery as well as with extra power from a new battery, but no success. Sad Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #325483 2nd May 2015 7:32am
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
I see this FH is a tag axle....far superior to twin steer set up 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #325527 2nd May 2015 12:56pm
Edfors
So with a new starter arrived from the island kingdom. I went to work.
Old and new starter. The old had a couple of draining tubes, but none on the new, nothing but a couple spouts.
So I installed two 20 cm pieces of rubber hoses to these spouts.
The original fault is probably corrosion and loose contact. Copper screw has damaged thread, so I will see if this can be replaced later.
New starter looks much better.
Gives and opportunity to inspect the flywheel, but no wear to be expected since the starter is a pre-engaged type with built in clutch. So the sprocket is always spinning.
And also a possibility to give the RH turbo a exterior visual inspection. Some minor oil leak can be seen.
I have the garage some 15 miles from home, so loaded up EDF on the trailer.
Convenient to be able to move two vehicles by yourself Thumbs Up
Further details on the starter replacement procedure can be found here http://www.fullfatrr.com/forum/topic31909.html
Past weekend, the Toylander got a new motor, one of the two motors in the Toylander had given up earlier. So good to have a couple LR's returned on duty again now. Makes both mrs and son a bit happier Thumbs Up
Post #328694 19th May 2015 8:52pm
Edfors
The weekend before last we joind a club out day with the Sörmland district of SLRK.
All line up properly on the turist/press parking.
Harpsund, the prime minister's offical summer residence the Swedish equivalent to UK Chequers.
This is a very typical landscape of Sörmland, the county south west of Stockholm.
We had a great day out with the friends from the local club.
Until this dreaded message showed up. "Engine system fault". Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #333717 21st Jun 2015 9:30am
Edfors
Me, having read about all turbo failures and not having any fault code reader become a bit nervous. Thought it was best to not risk anything big with EDF. So got home with help of a neighbour and then went back and picked up EDF on the trailer. During this trip we had two encounters with moose Shocked
Here's EDF in the far distance and our local moose calf in the foreground.
And EDF had to go on trailer back home.
And then another moose friend crossed the road just in front of us.
Good to have your own break down taxi Thumbs Up Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #334003 23rd Jun 2015 4:56am
Edfors
After reading about horror stories with turbos failing due to faulty EGR's and also after reading about all the possibly reasons for the Enginge System Fault to show, probably 95% is about a faulty EGR, I decided to replace both EGR's. When doing this I saw evidence in form of broken plastic clips on some connectors, that someone has been there before me, one of the EGR's are previously replaced! Anyway, decided to replace both so I know what I've got in there.
Old and new EGR valve.
Both new valves in place. The oil filter is suddenly very accessible as it stands tall in the centre Thumbs Up
I also decided to do 6 inlet hoses and some more o-rings and the gaskets required for the actual EGR's.
This was carried out on 125635 km on the odo.
Full write up of the EGR replacement can be found here http://www.fullfatrr.com/forum/topic32601.html Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #335200 29th Jun 2015 9:27pm
Edfors
Here some recent events for EDF.
EDF dressed up for graduation transport Thumbs Up
and stepped in to move a old harrow.
It's an original Ferguson harrow, but in quite bad shape... folded in three. But since it's original I don't want to dispose it, maybe I'll restore it one day...
And time to remove the far to road biased tyres with something more suitable.
This looks better Thumbs Up
Pulling the tin tent.
And the horse box.
One day this little cutie came and stayed at our door step.
We leashed him and after a few hours got hold of the owner by calling some neighbours. Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #343538 21st Aug 2015 5:32am
proser
I have just gone through this thread and have really enjoyed the contribution to the site. Thumbs Up Thumbs Up Bow down Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #343580 21st Aug 2015 10:10am
Edfors
Thank you Mark. Smile
EDF has behaved well over summer.
Here in company with a couple other fine pieces of British engineering, just 53 years apart. Fergie is getting ready for winter and also got new paint and rubber on the right front wheel.
On one of the trips this summer i had EDF on the scale and with luggage and 2 adults, 2 children is weighed in on exactly 3100 kg, so it's a heavy beast Thumbs Up Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #352117 13th Oct 2015 8:13pm
Just realised, your going to lose it soon.... first bit of snow and you won't be able to find it.... should have bought a black one.... Whistle
Love the Fergie.... Thumbs Up Pete
Post #352122 13th Oct 2015 8:59pm
wealy
Great write up
Post #352124 13th Oct 2015 9:04pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
really interesting thread. Thanks for sharing. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #352134 13th Oct 2015 10:17pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Fantastic thread - and many great photos Thumbs Up thanks Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #352174 14th Oct 2015 8:25am
Edfors
Last night, on our way to our weekend home we saw this moose, it was laying asleep in a neighbours garden and raised when we came close and lit it up with the light from the Range Rover.
Withers on this one is about 1.9 meters. Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #357908 21st Nov 2015 6:47am
