Home > Maintenance & Mods (L322) > Suspension Fault | 2008 RR VOGUE SC |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8283 |
You say you don't use it.... it is working every time you drive the car, always making adjustments to keep you level, so it does work hard even if you don't play with the buttons..
2nd Apr 2015 4:01pm |
luv2xlr8 Member Since: 29 Mar 2015 Location: Dubai Posts: 57 |
"Suspension Fault" appears…no particular reason but mainly when driving or at the traffic lights.
3rd Apr 2015 8:43am |
Big Tings Member Since: 03 Apr 2015 Location: Vogue Posts: 22 |
@Haylands, spot on mate just had to change my front passenger side due to a leak. If the compressor is working overtime to keep the leak inflated it will overheat and stop. Was driving mine on bump stops to get home after the bag let go on a trip. Note that the bags can reseal (leak hole becomes covered) until it is moved again by going over a bump etc. When we changed the passenger bag we took a look and the rubber had perished to the point that when we put it under manual load it was cracked all over. |
3rd Apr 2015 3:25pm |
Grabbing the car today, hope all goes smooth after the sensor replacement.
6th Apr 2015 6:42am |
Good news, car is driving just fine. If I hadn't rushed, would of cost me considerably less, its a first with the dealer so harm done and car drives just fine now.
8th Apr 2015 6:34am |
Back to to where it started, car on the ground, same messages
25th Jun 2015 1:14am |
Another sensor or a leak or possibility that someone has programmed the system into tight tolerance mode, this can make it work very hard and overheat the compressor...
25th Jun 2015 7:53am |
Brilliant how you jump out the rocks with the support and feed back, its rather exciting, thanks Haylands.
25th Jun 2015 11:08am |
Personally I wouldn't bother changing just the bag, FF's are heavy and the shock will be worn...
25th Jun 2015 11:36am |
Thank you sir. I'll have a look!
27th Jun 2015 10:48pm |
Fronts take about an hour, rears about 30mins... very quick to do...
27th Jun 2015 11:10pm |
Brilliant, thank you
28th Jun 2015 6:39am |
What needs tuning.....??? The engines tune themselves, there are no adjustments you can make, it either runs fine or something has failed....
28th Jun 2015 11:17am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
luv2xlr8 means calibration (tuning), I think.
28th Jun 2015 12:02pm |
