Home > Technical (L322) > tdv8 metallic whine |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 |
Sounds like a good strategy to me!
23rd Feb 2014 4:29pm |
ncow84 Member Since: 12 Jun 2015 Location: Banbridge Posts: 2 |
Sorry to dredge up an old thread but just thought I'd chip in to say mine has this exact same noise/vibration between 2-2.5k rpm. Engine seems to be running very sweetly, gearbox working without fault, just a slightly annoying feature when accelerating gently through this rev range, in any gear. Has anyone successfully dealt with this issue? Any new software updates for TCM / PCM that reduce the effect? It's encouraging to hear that Olders has made it 50k miles without it having any real ill effects, but would be nice to solve the issue and share with everyone. |
27th Jun 2015 7:22pm |
From my perspective, no. Haven't solved it. Just learnt to live with it! My car has now done over 120k, half of which this noise has been there for. It hasn't got any worse, hasn't got any better. Still running just as it has done for the last 60k. No change or degradation in performance or comfort.
28th Jun 2015 12:27am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
I have a 2009 vogue tdv8 with exactly the same issue. Done 100k and has been noticeable for the last 10k. Can't seem to pin point it though like you. it's more annoying than anything else as the car drives superb in every other way. Changed the trans oil and filter but made little difference. |
30th Aug 2015 10:51pm |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 251 |
Wow, great thread! I was going nuts over that lately. Only had my car for a month and kept thinking something was wrong with my transmission. Same issue - a small bit of noise and vibration at around 1900-2300 rpm, before gear change, totally rpm related, I can feel vibration through the gas pedal/floor. Maybe this is normal after all? |
2nd Sep 2015 5:03am |
So - do all of these make that noise/vibration effect? 12 4.4 TDV8 Vogue
24th Oct 2015 6:45pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Mine doesn't seem to. It's got 106k miles on it 2015 4.4 AB
24th Oct 2015 9:48pm |
Mine has now done nearly 130k and is still exactly as it was at 60k. No better no worse.
25th Oct 2015 2:11am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
I thought i would add that mine does this as well..............
19th Nov 2015 3:48pm |
jumbaleo Member Since: 19 Oct 2014 Location: Portsmouth Posts: 41 |
Mine too.
21st Nov 2015 10:47am |
Anybody want to add anymore to this thread?
14th Dec 2015 6:11pm |
I have read on another board that it may be a Torque Converter slowly failing but that would be strange as my car had a TC replaced not long before I bought it (well, at least according to the seller).
18th Dec 2015 4:33pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
Thread revival, I know, but I've seemingly got the same issue, with a sort of resonance between 1900 and 2400 rpm. Easier to notice when everything is up to operating temp.
12th Oct 2018 4:14pm |
