![]() | Home > Technical (L322) > 3.6 TDV8 EGR options? |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Ooops - should have mentioned - I got a price from Dan@Duckworths which was fantastic for a Garret unit (not exchange) at approx' �855 IIRC but like I said, I'm not too sure how long I'll have her. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1804 ![]() ![]() |
An EGR code will be logged, if there is a genuine EGR issue
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6762 ![]() ![]() ![]() |
The Indy that checked the O/S turbo when the fault first appeared and confirmed the actuator wasn't stiuck, or sticking.
Depending on the code, it may not be a physical actuator fault, but a boost pressure fault |
So a BT IIDTool would do the job?
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Our one is going in for its annual service Monday, my indy is trying to talk me in to a 're-map, says it will map out the egr valves, increase power, and improve consumption, with the exception of mapping out the troublesome egr`s, I'm not particularly bothered about the other stuff.
A non-BT tool will also do the job, but is a bit awkward to navigate and compare without the graphs Speak to Patrick @ Gap about upgrading. I know there have been a lot of D3 owners upgrade recently ![]() |
That's what I'm thinking Mike, non-BT without the live value graphs wouldn't really help I don't think? Got - 2017 SDV8 Autobiography in Loire Blue
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
Hi, today we've got our first two EGR related error codes - and the amber engine warning light - on our TDV8. The code read from the IID BT tool was "P140A-21 (2C)". After investigating this a bit, I found that it is related to the left EGR, signal low.
I�ve used and recorded live values from the IID BT tool, but I�m not an expert (to put it mildly!) to analyze and draw a conclusion based on these readings. To me it seems that the left EGR valve is less open (lower position values) than the right. When the EGR error code appears, the left EGR valve (#1) is stuck at max 5% opening.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I would try a Revive treatment for turbo and EGR problems. I used it on the RRV when I thought fuel consumption was up a bit. The motor had noticeably more power & seemed smoother running, not that it was running rough. I also used it on the Peugeot 407 hdi which had an EGR related surging problem. We initially fitted a blanking plate which fixed the problem, but then removed the plate used the Revive treatment. The surging hasn't returned. These are my only experiences with this product but both were positive. ______________________________
