![]() | Home > Technical (L322) > Towing electrics |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
Sorry, not much use, but I have the genuine electrics and I thought the correct operation was to _stop_ the suspension from trying to self level when a trailer was attached? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
^That's what mine does which I also understand to be the correct result to avoid unwanted height changes when towing. John
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
It's for safety as the default ride height (as I understood it) changes at speed. If your towing something more than a small trailer I'd play it safe and get the correct wiring |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
As it stands the car wont know it has a trailer attached without the dedicated wiring, either after market or Land-Rover. If you're using generic bypass relays that's your problem. The proper wiring will tell the car you have a trailer attached, it will modify the way the suspension works as well as change the way other systems react, gearbox, ABS, traction control etc.
Really? Mine doesn't even though it was configured on the diagnostics and has all genuine towing gear. But I can still lower the thing to aid unhitching etc. And it doesn't lock out off road height either.
It's what the handbook says it should do...
And for the gear change,
It should engage the trailer stability programme. Which does all that, and as you pointed out does the PDC and foglight cut out. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
The self levelling should work regardless of what electrics you have. It is the same principle if you fill the boot with bags of cement...... The height sensors detect that the back is lower than the front, and increase the pressure to the rear bags to compensate.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
All seems well as it were , I have the correct wiring and modules, the only bit that is missing is that the car has not been programmed to recognise it!!!
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
How much are the stealers charging to tell the car wiring elect are fitted? (if you don't mind me asking)
Don't know is the answer to the question! But they charge £90 per hour so hoping they can do it within that time??
