Home > Technical (L322) > Towing electrics
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Towing electrics
Mods, please move if in the wrong section!
Just been reading the manual and it says that my car should level itself when my caravan is attached? Mine doesn't which maybe means that I need to change the towbar electrics to genuine Land Rover?
Can anyone give me any pointers??
Thanks in advance
David 2014 vogue se
Post #330604 2nd Jun 2015 3:33pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Sorry, not much use, but I have the genuine electrics and I thought the correct operation was to _stop_ the suspension from trying to self level when a trailer was attached?
Post #330607 2nd Jun 2015 3:38pm
Weegie
^That's what mine does which I also understand to be the correct result to avoid unwanted height changes when towing. John
GAP iiD BT
Post #330611 2nd Jun 2015 3:57pm
n1cktdv8
It's for safety as the default ride height (as I understood it) changes at speed. If your towing something more than a small trailer I'd play it safe and get the correct wiring Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #330614 2nd Jun 2015 4:27pm
Zirconblue
As it stands the car wont know it has a trailer attached without the dedicated wiring, either after market or Land-Rover. If you're using generic bypass relays that's your problem. The proper wiring will tell the car you have a trailer attached, it will modify the way the suspension works as well as change the way other systems react, gearbox, ABS, traction control etc.
It should still lift the back up i think, because it's just like loading the boot up. Have you got the nose weight too high on the caravan? The caravans drawbar will have a weight limit as well as the vertical load on the cars tow hitch. You do see a lot of badly loaded caravans on the motorway....
What it will do is lock the suspension at the standard ride height when a trailer is connected, although it should still level the car to that height providing the weight imposed on it isn't too high. The reasoning for this is if you have a particularly low trailer and raise the suspension to off road height then the back of the trailer could hit the road, it could also affect stability, as if the trailers nose is pointing upwards it has a tendency to try and lift the back of the car if you brake hard. Then you get the opposite if the car lowers its self.
Post #330616 2nd Jun 2015 4:37pm
mzplcg
Really? Mine doesn't even though it was configured on the diagnostics and has all genuine towing gear. But I can still lower the thing to aid unhitching etc. And it doesn't lock out off road height either.
What it does do is disable rear park sensors and rear fog lights on the car to prevent glare off the trailer. But beyond that I can't find any other differences.
Post #330646 2nd Jun 2015 6:49pm
Zirconblue
It's what the handbook says it should do...
Quote:
"TOWING A TRAILER
When the electrical plug for a trailer attachment
is connected to the vehicle socket, the EAS
controller acts as though the inhibit button is
activated. The only height change which is
accepted is a return to standard height, if the
vehicle is not already at standard height. The
standard height indicator light and the inhibit
light are illuminated. Once standard height is
reached, no other ride height change will be
available.
WARNING
If the vehicle is at any ride height other than
standard height, when a trailer is fitted,
trailer weight distribution and balance may be
affected when the vehicle returns to standard
height."
And for the gear change,
Quote:
Electronically selected gearbox modes
A suitable gear change pattern for trailer
towing, hill ascent and high altitude is selected
electronically and retains lower gears for
longer. This feature is enabled to counter
momentum loss caused by more frequent gear
changing, which can occur when climbing hills
or when towing a trailer or caravan. This gear
change pattern is also selected at high altitudes
to combat reduced engine torque.
It should engage the trailer stability programme. Which does all that, and as you pointed out does the PDC and foglight cut out.
Post #330652 2nd Jun 2015 7:20pm
The self levelling should work regardless of what electrics you have. It is the same principle if you fill the boot with bags of cement...... The height sensors detect that the back is lower than the front, and increase the pressure to the rear bags to compensate.
The trailer electrics just stop it changing height automatically to motorway height! Which you should not be towing at a speed high enough to trigger in any case.... Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #330653 2nd Jun 2015 7:23pm
chefkenmore
All seems well as it were , I have the correct wiring and modules, the only bit that is missing is that the car has not been programmed to recognise it!!!
It could be that I had a new battery fitted when I first got the car, and maybe it has forgot the settings????
Anyway, booked into the stealers next week to get it sorted along with a couple of recalls!!
Cheers
David 2014 vogue se
Post #334230 24th Jun 2015 3:34pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
How much are the stealers charging to tell the car wiring elect are fitted? (if you don't mind me asking)
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #334233 24th Jun 2015 3:56pm
chefkenmore
Don't know is the answer to the question! But they charge £90 per hour so hoping they can do it within that time??
Can the IID tool do this??
David 2014 vogue se
Post #334238 24th Jun 2015 4:10pm
