Home > Technical (L322) > Can I stop the mirrors folding when I lock the car |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I only think it can be done via the CCF files so, by someone with appropriate diagnostics kit sir...
24th Jun 2015 8:10am |
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 |
I have gone through the menu but there doesn't seem to be the option. In a Mercedes you can select the auto fold function on or off. To be honest I am not sure what a CCF file is, would a main dealer be able to do do that? Thanks 2010 5.0 SC Autobiography |
24th Jun 2015 8:43am |
Sorry my friend... Car Configuration Files... Think of them as the DNA, you have hundreds of them and dependant as to what spec your car has, or has not! Depends what extra’s you order from factory or dealer, they simply plug your car in and switch the appropriate CCF ON or OFF...
24th Jun 2015 8:59am |
Craig - thank you for the very quick reply, really helpful. I also hadn't thought about the mirrors being out giving the appearance that the car is unlocked. 2010 5.0 SC Autobiography |
24th Jun 2015 9:15am |
24th Jun 2015 10:08am |
Just in case it helps someone else, I took the car into Lookers and the short answer is they cannot turn off the mirror auto fold. They showed me the print out of what they could alter and they are; Day light running lights, Speed dependent front windshield wipers, Rear continuous wipers, 3 flash turn signals and Exit (not sure exactly what Exit relates to). 2010 5.0 SC Autobiography |
28th Jun 2015 10:11pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
Was looking at this as well as the folding is not necessary most of the time. The handbook simply tells you that they will fold.... No hint that they can be turned off...... There is nothing that can't be fixed with a hammer😜😜
28th Jun 2015 10:20pm |
IID tool will do it |
28th Jun 2015 11:10pm |
Thanks, sounds like I need to do some reading up. 2010 5.0 SC Autobiography |
28th Jun 2015 11:38pm |
Well you certainly can on our pro model so, you just need to check it can be done on their regular BT model sir |
28th Jun 2015 11:46pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
given the cost of a replacement mirror i think i'd leave it set how it is.
29th Jun 2015 1:24pm |
This car is a keeper so just having the mirrors folding and unfolding hundreds of times a year, for no reason it seemed sensible to see if you can turn off the function. You can on every other car I have had. The car is 5 years old with 40,000 miles and when they fold they already sound a bit squeaky and worn. I don't know what the cost of two new mirror motors and fold mechanisms are and the hassle of changing them but I was hoping just turning them off would be cheaper, if you don't need it. I have spoken to Britpart and their IID BT Part number DA6414 can turn off the mirrors, so I might just treat myself to one anyway which I am sure will be useful for the future. 2010 5.0 SC Autobiography |
29th Jun 2015 1:37pm |
If you're planning on keeping the car then an IID is a sound investment.
29th Jun 2015 1:40pm |
Thanks, I will get the spray out. 2010 5.0 SC Autobiography |
29th Jun 2015 2:14pm |
