Home > General > Has anyone got an Ifor Williams trailer and Farmers hitch
Zirconblue
I'm picking up a 16ft ifor williams flatbed/dropside on saturday.
Has anyone got one and use the farmers hitch? If so which level do you have the tow ball in?
Mines currently in the middle set of holes, but i did notice my small box trailer sits a but low on it.
Just means i can move the towball up or down before i go. Save taking the torque wrench etc with me.
Post #333823 22nd Jun 2015 12:04am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I've got one of the large Ifor car transporters, and I've got the tow ball in the top holes on my farmers hitch.
Post #333836 22nd Jun 2015 6:32am
RiccartonRR
I'd like to see what type of farmers hitch you have - mine only had two sets of holes (Westfalia).
To get my LM146G Tri to sit level I had to drill a set of holes higher up and now it's bang on.
My advice would be to put yours up to the highest set of holes before you collect and then re-evaluate once you get home. A trailer which is a couple of inches too high at the front will tow fine but one too low is dangerous IMHO.
Good luck and happy new Ifor Thumbs Up
Post #333838 22nd Jun 2015 6:46am
mzplcg
Yep, top set of holes for my GD105 as well. Thumbs Up
Post #333846 22nd Jun 2015 8:01am
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Again, top set of holes for HB511 and GD84
Post #333850 22nd Jun 2015 8:38am
Another vote for top
Though I agree with RiccartonRR, it still feels slightly too low.
Post #333867 22nd Jun 2015 9:44am
Zirconblue
Excellent will move the ball up before i go.
I have this hitch, http://www.pfjones.co.uk/range-rover-2002-flange-tow-bar-1.html There are two holes further up, and two more 'just' below the middle ones.
I'm actually struggling to see the point of the lower two sets of holes, i mean even my little 8" wheel Erde box trailer seems nose down on the middle hole, i suppose it would level off a bit with weight in it.
Post #333879 22nd Jun 2015 12:16pm
I know it won't help the OP but may help others. I tow ifor tri & twin axle traitors both are tilt beds and you can adjust the bed to suit (by closing the tilt bed on a spacer bar and extending the lock bars a turn or ten!) that way we can have the trailer perfectly flat on a detachable tow bar...
Maybe worth considering next time anyone orders an ifor as the tilt bed is not too much of an extra... Thumbs Up
Post #333966 22nd Jun 2015 7:32pm
Zirconblue
Does that adjust the wheels too though? Although mine isn't a tilt bed, I was more concerns about the wheels being on the ground evenly. If it's nose down then the front axle could be over loaded while the rear is only just touching the ground.
Post #333970 22nd Jun 2015 7:39pm
Yes, that's exactly what it does... As the bed tilts, even by half an inch it lifts the wheels that end by 3 or 4 inches... Hence levelling the trailer to your car... Thumbs Up
Post #334001 23rd Jun 2015 2:25am
RiccartonRR
Unfortunately the tilt bed system only applies to transporters and not to flat beds (LM series) or horse boxes (HB series).
Wouldn't it have just been simpler for LR to put the ruddy towbar at the correct height in the first place Big Cry
Post #334008 23rd Jun 2015 7:54am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Need to watch the back bumper using the top hole - some hitches get very close with the factory ball.
Post #334018 23rd Jun 2015 10:01am
RiccartonRR
You're right there - you need the Westfalia extended ball suitable for stabilising hitches Thumbs Up
Still 'kin close though Big Cry
Post #334056 23rd Jun 2015 12:38pm
When you say transporters... I presume you mean car transporters? Mine is the farmer type flatbed with sides and a tilting hydronic bed for easy loading of sports cars...
Whistle
Post #334067 23rd Jun 2015 1:38pm
RiccartonRR
Embarassed I stand corrected Bow down Bow down Forgot the new TB range.
Just need to find a tilt-bed version of the HB now and LR can make towbars as low as they want Rolling with laughter Rolling with laughter
Post #334071 23rd Jun 2015 1:56pm
