Home > In Car Electronics (L322) > Cigar Lighters |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
I would like to change the front and rear cigar lighters (not the accessory sockets) to ignition switched as they get used for ancillary equipment and it would be more convenient to have them isolated when the ignition is off.
19th Jun 2015 9:25am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
this came up a while back john and i suggested running feed wires from an ignition live socket but i'm sure someone came up with a better idea of changing the permanent live socket to an ignition live but i cant remember how.. ... - .- -.
19th Jun 2015 9:35am |
Thanks, Stan. Will see if anyone has an idea. John
19th Jun 2015 10:18am |
i think this is the thread but its ignition live to permanent live thats been talked about..maybe the opposite can be done..
19th Jun 2015 11:04am |
Nice one, Stan. Had a look and the relay is not there and there is a bridge in situ. Will look to acquire a relay (R132) which should, hopefully, do the trick. Need to source one. John
19th Jun 2015 11:44am |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Hi Weegie,
19th Jun 2015 12:37pm |
Rear compartment fuse box bridge instead of missing relay arrowed:
19th Jun 2015 4:06pm |
Thanks... You seem to have a slightly different set-up than mine... No bridge nor a relay for me... yet still my sockets are all live despite the engine turned off... You also have lots more of fuses....
19th Jun 2015 10:21pm |
Not sure but if you look at page 167 onwards on the above link it may give you a clue. It could well be that it is connected elsewhere than the rear fuse box.
20th Jun 2015 7:01am |
Yeah already looked at page 167 and onwards. But it's a bit abracadabra to me.
20th Jun 2015 7:29am |
I wouldn't like to comment on that. John
20th Jun 2015 8:30am |
Cheet22 Member Since: 28 May 2015 Location: Hamilton Posts: 27 |
Just looked at that link to wiring diagrams.
20th Jun 2015 9:00am |
Ethanicus Member Since: 23 Feb 2015 Location: Surrey Posts: 34 |
Could you wire an inline voltage sensitive relay to kill the feed when the engine is off. 2010 - Range Rover VSE 3.6 TDV8
20th Jun 2015 9:03am |
Accordng to page 17, a switched relay should control in car sockets..... |
20th Jun 2015 9:11am |
