Home > General (L405) > Wind noise at drivers side only
scanner
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Has anybody noted higher wind noise sounding through at 60mph+? I suspect it is down to the trim which runs along the car just under the windows. The rear section seems to be opening up from the car to be in the airflow by 4mm. Is that enough to make the noise?
Dealer is fixing it anyway. 2010 TDV8 Zermat Silver with dirty streaks
2013 L405 3L Vogue SE Corris grey
Post #331652 9th Jun 2015 1:03pm
Ginger
2006 Range Rover Vogue 4.4 V8 Santorini Black
Hi Scanner
The plastic scuttle at the bottom of the windscreen where the wiper shafts protrude can become warped and cause some noise in the cabin.
Post #331666 9th Jun 2015 4:14pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
I've noticed a small but mildly irritating wind noise at speed. I guess it's partly down to the car being so quiet?
Post #331677 9th Jun 2015 5:02pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
No such noise on mine after 18 months/20K miles (up to 70 mph only of course officer Wink ) Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #331726 9th Jun 2015 8:49pm
Doodle
Yes, have the same issue at speeds around 70.
Depending upon road surface, it varies from barely audible to extreme. (Rough road = extreme roar.)
It's as if the driver's door frame surround flexes. In fact as you run your fingers along the top door seal the gap can be felt.
The seal is a poor fit and replacing with same makes no difference. Solution seems to be removing seal and hammering the frame lip inwards. This reduces the gap and so the seal then does its job.
Should have had decent quality seal in first place. Not impressed.
Post #331753 9th Jun 2015 10:28pm
J4cko
United Kingdom 2015 Range Rover Autobiography SDV8 Barossa
There's a software fix for it. The electric window motor reduces it's torque in the final bit of travel - too much it seems! The software update fixes this - mines just been done. before I got round to having it fettled, a couple of pulls on the close button did the same thing - almost became second nature!
Messing with the trim or bending anything isn't fixing the underlying issue although it does seem more like proper fixing than resorting to a laptop Smile
Cheers,
H
Post #333097 18th Jun 2015 10:52am
