Home > Technical (L322) > Racked off!!! ;)
Wofforduk
United Kingdom 2007 Range Rover Vogue TDV8 Adriatic Blue
Racked off!!! ;)
Have a bush gone in the RR TDV8 steering rack. My friendly Indie sat me down before giving a price for a new rack, good job too... 1800 exvat!!
He did say that if i can get the bush off, it will be more like a 50 quid job, which id rather go for but it may not be removable, only the disco 3s and sports have the removable ones..?
Has anyone had the bush go, under the rubber garter, and is it removable? its on the drivers side.
Cheers! Smile
Post #329930 29th May 2015 2:16pm
mzplcg
Probably. Not done a FFRR personally but I have done loads of others, all teh same principle really. See if you can get a service kit from ZF.
Also take a look at this thread.
http://www.fullfatrr.com/forum/topic31980.html
Post #329931 29th May 2015 2:19pm
Wofforduk
Thanks mate
Seems that they point that the nylon bush can be replaced easily/cheaply...
Spanners out i guess.!
Post #329933 29th May 2015 2:23pm
Wofforduk
Turns out im really not sure if this is a bush.
I was only going on what my indie has said.
trying to find out what the heck this clunk noise is coming from.... happens when i go from lock to lock. its a pretty decent clunk, quite loud and can feel it when driving. No excessive play in the steering rack.
i got a friend to turn the wheel from side to side whilst i was underneith, feeling all the joints. the only joint that i could feel some movement was the LH tie bar.
Just wondering if anyone has had this issue and what they did to cure it!! (im not excluding the rack.... just want to get a few options before!)
cheers
Post #330893 3rd Jun 2015 10:48pm
As far as I can tell you are referring to the inner track rod joint, as that is what is under the gaiter.
Definitely changeable, part is cheap and it's easy to change.
http://www.eurocarparts.com/mobile/ecp/c/L...amp;000347
Had both of mine done, get the lemforder ones as these are oem, and not much more than the aftermarket ones. There is nothing that can't be fixed with a hammer😜😜
Post #332297 13th Jun 2015 6:48am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I would also suspect the inner track rod - the LHS one on mine went and it used to clunk noticeably
Local indie changed it for £60 including the part (I'm sure it's not OEM but 30k miles later it's still fine) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #332300 13th Jun 2015 7:08am
Check the rack securing bolts too... Have found a couple loose now which creates the most hideous knocking noise! Rolling Eyes
One big nut & bolt either side... Takes a huge torque figure to tighten them from memory Thumbs Up
Post #332303 13th Jun 2015 7:51am
Given I don't have a torque wrench (must get one) I do a lot of "tightening from memory" Very Happy .
Post #332313 13th Jun 2015 9:11am
