Home > Technical (L322) > What should the charging voltage be with engine running? |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
14v ish at idle. 14.4v @ 2k RPM.
10th Jun 2015 12:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
my 4.2 sc voltage is the same as steves. ... - .- -.
10th Jun 2015 12:33pm |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Hi, thanks for this great advice. I went out and did what you said and put all electrics on then held her at 2k revs for a while. The voltage still didnt go above 13.7v.
10th Jun 2015 12:53pm |
Had the same symptoms myself. It is worth checking and double checking all the connections but I suspect a new alternator will do the job. I suspect it's the regulator that is at fault but as I couldn't find anyone to repair this alone, I had the buy the whole alternator.
10th Jun 2015 1:01pm |
Thanks mate thats good to know, i had a look online and it seems a new one is around £120 so not bad at all. Did you fit yours yourself, how hard was it if so? the viscous fan has been removed on mine so i dont have that to contend with atleast |
10th Jun 2015 1:07pm |
A mechanic mate fitted mine, £50 on a Saturday morning.
10th Jun 2015 8:04pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
Interesting thread.
11th Jun 2015 5:06pm |
