Home > Technical (L322) > What should the charging voltage be with engine running?
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hi, i noticed today my range rover battery voltage is 13.7v with the engine running and doesnt go over that. Is this on the low side? I checked my van and that has a new alternator and charges at 14.3v.
Im wondering now if this could be the cause of my occasional trans safe fail message? the battery is new on the RR.
What does yours read with the engine running guys? thanks
Post #331845 10th Jun 2015 11:56am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
14v ish at idle. 14.4v @ 2k RPM.
Put everything electric on and dial up 2k revs and should be at least 14.2v+ But not more than 14.5v
How does your behave at 2k RPM and with various loads?
If it's low, it is indeed a TFSP warning possibility. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #331846 10th Jun 2015 12:03pm
my 4.2 sc voltage is the same as steves. ... - .- -.
Post #331851 10th Jun 2015 12:33pm
JPS
Hi, thanks for this great advice. I went out and did what you said and put all electrics on then held her at 2k revs for a while. The voltage still didnt go above 13.7v.
I have also noticed at night time the battery light is on but is very very dim you can hardly see it.
Does it sound like my alternator isnt working correctly do you think? Thanks in advance.
Post #331854 10th Jun 2015 12:53pm
SKOT
Had the same symptoms myself. It is worth checking and double checking all the connections but I suspect a new alternator will do the job. I suspect it's the regulator that is at fault but as I couldn't find anyone to repair this alone, I had the buy the whole alternator.
TD6 one is not too expensive (compared to the BMW 4.4 V8 water cooled one at any rate) and fitting wasn't too bad.
My 5p. Good luck with it. Thumbs Up 2006 4.2 SC
Post #331855 10th Jun 2015 1:01pm
JPS
Thanks mate thats good to know, i had a look online and it seems a new one is around £120 so not bad at all. Did you fit yours yourself, how hard was it if so? the viscous fan has been removed on mine so i dont have that to contend with atleast Laughing
Post #331856 10th Jun 2015 1:07pm
SKOT
A mechanic mate fitted mine, £50 on a Saturday morning.
Waaaaayyy beyond my capability! Sad 2006 4.2 SC
Post #331925 10th Jun 2015 8:04pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Interesting thread.
Do likely voltages vary with models? Out of interest i did the switch on / 2 k revs thing with mine...
13.95V with everything on and 2k, then 14.0 at idle with nothing switched on, and 14.0 at 2k with nothing switched on. In other words 14 whatever is happening (give or take a nats whisker).
Is this abnormal?
Cheers Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #332070 11th Jun 2015 5:06pm
