![]() | Home > Camping, Caravanning and Holidays > Pulling the tintent! |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
It's not a rule it's purely a recommendation for those new to towing. Assuming the RR is 2800 then it is 86%. Ian |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
I wasn't talking literally when I said that! |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I had mine out for the 2nd time with the FF over weekend. I used to think the D2 was good but the FF is in a different league. Everything about it is better, I still can't quite believe the difference, it's effortless |
What chassis is that on then? Both the BPW and the ALKO have a pair of 1000KG axles. Add either 100 (Alko) or 150 (BPW) kilos for the noseweight and it's still over the chassis makers design weight. |
It's on a BPW with axles rated at 1200.
Andrew5331 Member Since: 26 May 2015 Location: Southlanarkshire Posts: 74 ![]() ![]() |
[image]Here is my l200 but not for much longer as I pick up my rrtdv8 4.4
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Just back from a week on Anglesey, as always a solid tow at 22mpg fully laden with bikes and everything for 5 people.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8671 ![]() ![]() ![]() |
Woke up his weekend to water running in the roof of my 2010 lunar. |
+1 on that. Really should be Sikaflex all over as it doesn't set but worth a check.
Also Just re done the front rail above the windows today, as that had also dried at one end and was really crusty underneath. As it is a pita to clean it all off I re did it in IDL 99 which is what it was in the first place. Easy job but total ball ache to get all of the mastic which squeezes out off the front of the van.
acc Member Since: 06 Dec 2014 Location: Essex Posts: 6 ![]() ![]() ![]() |
Hi all,
Looks like a Bessacar to me👍 There is nothing that can't be fixed with a hammer😜😜
Spot on, it's Bessie 645. |
