Home > Maintenance & Mods (L322) > Battery drain due to headlamps?
abs123
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Hi all
I am new to Range Rovers and new forum.
I am the proud but bewildered owner of a 2004 Range Rover vogue TD6 which has had a 2006 facelift conversion done on it.
since day one of my ownership the car has suffered from a huge battery drain which causes the battery to go flat after 2 days of parking the car up.
i have since changed FSR and a new battery but still it persists.
since then it has been with Les Pauls in redbridge essex who have found that when unplugging the headlights the battery drain stops.
i know the headlights need different connectors so would have been changed when the conversion was done.
does anyone having a conversion wiring diagram please
what can be the cause of this and anyone know of any fixes?
many thanks in advance
Post #331708 9th Jun 2015 7:02pm
have a read here,
http://www.fullfatrr.com/forum/post251640.html?#251640 ... - .- -.
Post #331717 9th Jun 2015 7:20pm
abs123
Thanks for the reply Stan
The diagram in your post ... Is that the same as to how it should wired when converting a 2004 to 2006 facelift ?
Post #331782 10th Jun 2015 6:52am
sorry got the years wrong, this should help,
http://www.fullfatrr.com/forum/post104903.html#104903 ... - .- -.
Post #331788 10th Jun 2015 7:14am
