Home > Technical (L322) > TDV8 08MY - no throttle response when trailer connected? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Sounds like you've just re-initialised the trailer ECU by unplgging/reconnecting it.
8th Jun 2015 5:40pm |
Beau Member Since: 12 Jul 2014 Location: Dorset Posts: 53 |
Thanks Zirconblue,
8th Jun 2015 6:06pm |
There is yes, it detects when a trailer is attached and changes the way the car behaves, locks suspension to the standard ride height, changes the way the DSC works, changes the gear change map, checks trailer lights, inhibits the parking sensors and fog light etc. At least it should have but of course some cheap tow bar fitters just use generic bypass relays.
8th Jun 2015 7:11pm |
Very interesting: it should all be kosher genuine bits and to be honest it does feel like it behaves differently when the trailer is plugged in. I'll have a good look through the trailer and the Rangie wiring - one item that could be a weak link I guess is that I fitted the Euro socket to the Rangie and then have an adapter to the 7-pin electrics on the trailer...
8th Jun 2015 7:21pm |
