Home > Technical (L322) > squeak from rear o/s very annoying |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
If you have a blue coloured bush, then it sounds like a Poly one, they transmit more noise/vibration than rubber, but they last a lot longer - one of the other draw backs is they can squeak unless they're greased when fitted. Spray a bit if silicone lubricant (or WD40) on it and see if that stops the noise. If it doesn't, try spraying other possible sources of the noise one at a time. When it all goes quiet you'll have isolated which part the noise is coming from, the effect might only last a few days, but at least you know which part to replace. |
8th Jun 2015 7:18pm |
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 |
1cheers zicon, yes i first thought poly as well, the squeak seems to be coming from the other side though. I have squirted all moving joints and components with WD over the last week on the n/s with no effect |
8th Jun 2015 7:51pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 338 |
I have the same issue and the old WD40 has been out and the squeak is still there! If I find the source I'll let you know!
8th Jun 2015 9:38pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Usually a dry ball joint When you think you have worked out which one it is, prick it with a braddle and spray with WD40 can with a straw attachment. |
8th Jun 2015 9:40pm |
Thank you Sir; I'll report back when I've pricked the offending ball!
8th Jun 2015 10:54pm |
That's proper Wess-Vinglun speak that I take it you mean a Bradawl, just with a Jethro style accent Craig. |
9th Jun 2015 7:06am |
