Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8 |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
Hi mate,
8th Jun 2015 7:47am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Thanks Jake. Yes I noticed that too. If not will phone around tomorrow. I suspect it will be tranny out to get any clear idea of the problem. ______________________________
8th Jun 2015 7:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Until you get someone knowledgable to look at it sir everyone here would just be guessing... As you rightly said it could be the transmission, could also be any of these too the front or rear diff, one of 4 driveshafts, transfer box broken...
8th Jun 2015 8:07am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2492 |
I suspect transfer box motor or calibration, range sensor or solenoid as the hi/lo LEDs are flashing. |
8th Jun 2015 8:33am |
The man that can help you is RRPhil, our resident gearbox god.
8th Jun 2015 8:43am |
Thanks all for the replies.
8th Jun 2015 9:21am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
Does the park lock hold the vehicle with the hand brake off or does it just roll freely?
8th Jun 2015 9:41am |
The hand brake and park all work as normal. There's no unusual noise in park or neutral. ______________________________
8th Jun 2015 10:15am |
Would appear to be a transmission issue then, rather than something downstream. It’s just that we’ve had a couple of instances on here of 6HP26’s failing because the output shaft hadn’t apparently been coated with anti-seize grease at the factory and the spline into the transfer box had subsequently failed/worn away through fretting corrosion. Anyway, if your park lock holds then this would rule out this particular cause.
8th Jun 2015 11:10am |
Thanks Phil. ______________________________
8th Jun 2015 7:16pm |
Scrap that Phil. I double checked this morning and park is not holding. So it could be as you say. Is the fix a big job? Should I get anything else done while the box is out? ______________________________
8th Jun 2015 9:21pm |
Also, Park will only hold if you have a complete drive train... i.e. 4 driveshafts, 2 working diffs, props shafts etc etc so well worth checking them first sir |
8th Jun 2015 9:34pm |
Thanks Cam, yes I started thinking back to your possibilities. So handbrake on, jack it up one corner at a time, and check each wheel for movement and noise, starting at rear? ______________________________
8th Jun 2015 9:53pm |
No handbrake as that will lock the rear wheels sir... (the handbrake is like a regular car these days) |
8th Jun 2015 9:56pm |
