Home > Technical (L322) > Check coolant Level intermittant warning |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
2004 TD6 - Is there a step by step idiot proof guide to fault finding that warning? I have been driving for about 6 months now and this just started showing every other day, I had a look and the reservoir seems ok so I assume its just a gremlin like the ones I get in my XJ8 when the battery gets low or is it an actual problem? I am overdue a service so maybe that has something to do with it but I thought I would ask so I can pre-empt any questions when I leave it in to get looked at |
6th Jun 2015 10:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
http://www.fullfatrr.com/forum/topic20913.html
6th Jun 2015 12:42pm |
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 |
Also if your antifreeze mixture isn't right it brings on the alarm
6th Jun 2015 1:03pm |
6th Jun 2015 1:05pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Changing just the sensor may not be enough. You may need to change the whole coolant tank and sensor. .
6th Jun 2015 2:28pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Joe's right. |
6th Jun 2015 8:09pm |
