Home > Technical (L322) > Check coolant Level intermittant warning
Brian
2004 TD6 - Is there a step by step idiot proof guide to fault finding that warning? I have been driving for about 6 months now and this just started showing every other day, I had a look and the reservoir seems ok so I assume its just a gremlin like the ones I get in my XJ8 when the battery gets low or is it an actual problem? I am overdue a service so maybe that has something to do with it but I thought I would ask so I can pre-empt any questions when I leave it in to get looked at
Post #331239 6th Jun 2015 10:44am
http://www.fullfatrr.com/forum/topic20913.html
''Over time, the sensor (Part number PCJ000020) can stop working, or just become a bit over sensitive, and alert to low level of coolant even when coolant level is fine. You need to change the sensor.''
Thumbs Up ... - .- -.
Post #331248 6th Jun 2015 12:42pm
texpis
England 2002 Range Rover HSE 4.4 V8 Alveston Red
Also if your antifreeze mixture isn't right it brings on the alarm
Mick
Post #331254 6th Jun 2015 1:03pm
Brian
ta
Post #331255 6th Jun 2015 1:05pm
Changing just the sensor may not be enough. You may need to change the whole coolant tank and sensor. Thumbs Up .
Post #331270 6th Jun 2015 2:28pm
RR2008HSE
Joe's right. Thumbs Up
Post #331328 6th Jun 2015 8:09pm
