Home > In Car Electronics (L322) > Rear Door Speaker rattle
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Sometime over the last couple of weeks my car started making an annoying vibrating noise when the stereo was turned up. On Saturday a mate pinpointed the noise to be coming from the offside lower rear door speaker and sure enough adjusting the fader to the front caused the noise to vanish.
So on Sunday I removed the door panel to make sure it was not a simple loose screw / fitting / clip and I confirmed the noise was coming from the speaker cone itself.
The noise continued yesterday so I booked the car into the dealers for a replacement speaker for this coming Friday.
Typically on my way home from work this evening the noise has stopped - No doubt the dealers will think I'm making it up and then noise will restart on my way home from them.
I can cope with the occasional problem, but rattles and vibrations are the one thing that makes my blood boil when I'm driving (that and middle lane morons)
Gone - Range Rover Supercharged 2006
Post #71340 5th Jul 2011 8:22pm
thats typical of the FFRR, one minute you have a problem , the next its gone.....same with my 'noise' behind the console when the a/c button is pressed, day before yeterday theres a noise, yesterday no noise. Rolling Eyes
your speaker sounds like its breaking down, like when you turn up a stereo to full volume and the speaker blows..i've found that the little wires that are glued onto the diaphragm come loose because the glue goes brittle and causes speaker failure.... any signs of water ingress, if no its probably just wear and tear..
Post #71364 6th Jul 2011 7:09am
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
got the same issue myself, learnt to live with it TBH. Mine only seems to happen with the radio Shocked CD player on and sounds great!! Intermittent as well. I found that reconnection of the amp plug sometimes sorts it out Thumbs Up but then it only comes back again Censored Censored
Post #71366 6th Jul 2011 8:26am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
i now have the same failure on MY06.
is the lower rear speaker mounted with screws?
it should be part nur XQM500230.
thanks
Post #330363 1st Jun 2015 7:12am
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
I have the same problem with my lower speakers in the rear doors XQM500100's , I have repaired them twice already but today I bit the bullet and ordered 2 XQM500410s these are the ones that supersede the originals it was just under £200 for the pair Shocked 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #331016 4th Jun 2015 6:29pm
tafftoo
2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have the same intermittant problem with the same speaker... Did the replacements fix it or was it caused by something else?
Post #331019 4th Jun 2015 6:42pm
Paul_H
I am positive the replacement speakers will resolve it, I will keep you posted Wink 2005 Range Rover Vogue with Supercharged Accessories
Post #331021 4th Jun 2015 6:44pm
clemenz
can you then make some pictures of the mounting? thanks
Post #331268 6th Jun 2015 2:14pm
Paul_H
Clemenz
The speakers are a direct replacement for the original ones, all fit perfectly and took me about 30 minutes to change both side Thumbs Up 2005 Range Rover Vogue with Supercharged Accessories
Post #331698 9th Jun 2015 5:56pm
clemenz
so with screws? Very Happy
Post #331840 10th Jun 2015 11:40am
Paul_H
Well after a couple of weeks with the new speakers I have to say they are a massive improvement, sound appears to be cleaner and more defined, every little background sound can be clearly heard 😎😎😎 2005 Range Rover Vogue with Supercharged Accessories
Post #334569 26th Jun 2015 5:49pm
clemenz
i have not yet replaced mine, can the old ones be repaired?
would it be possible to re glue them?
Post #373849 24th Feb 2016 9:25am
