Home > Technical (L322) > Westfalia removable tow bar |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Can't comment on the lock but I don't understand your question about the electrics. If they are fitted the socket should be apparent attached to the armature next to the tow hook point. In which case all you should need to do is lift the lid and count the number of pins? John
4th Jun 2015 5:43pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I believe the manufacturers warranty covers all approved accessories that were fitted when the car was supplied new. So yes, they should cover the tow bar - If not, you can buy the removable section from PF Jones, but more cheaply than Land-Rover, Less than Half the price!
Andrew5331 Member Since: 26 May 2015 Location: Southlanarkshire Posts: 74 |
Had a look the sockets are there but they are up behind the bumper there is a ab body kit on it from the factory and it covers the pins I'll try adding more photos |
4th Jun 2015 5:47pm |
Understood. You say sockets. If you have two then they are 12N and 12S not 13 pin but you can get an adapter to use them as 13 pin.eg http://sargentshop.co.uk/13-Pin-Socket-Adaptor . This might help http://www.caravanclub.co.uk/media/1022790/towbar-wiring-mo.pdf John
4th Jun 2015 6:01pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Andrew, you have the same OE bodykit as mine... There are 4 turn clips under the centre panel, (mine is painted black, see pic bellow. Yours will be matte grey if factory standard) turn them 90 degrees and they should drop out by about an inch. Then just pull the lower section off sir
4th Jun 2015 9:10pm |
Ok thanks Craig I'll have a look 2morrow thanks got it booked in to LR on Monday to check it over along with a few other things I'll post back with there verdict |
4th Jun 2015 9:37pm |
Ok put the car into the dealer to get it checked over they are saying it is not been fitted by them but I think it has been as I was told that it is a factory original car with out any additions I've taken a few pictures of booklets that were in the log book and they all look if it is a LR part how can I check if it was done by them
11th Jun 2015 5:58am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
The lock portion has dropped out of the centre of the armature - exactly the same happend to mine. Its a very costly part that you see on ebay for about 200 quid. I was told that you can buy a replacement lock mechanism for about 25 quid but I couldn't source one.
11th Jun 2015 10:48am |
http://www.pfjones.co.uk/range-rover-2002-...w-bar.html
11th Jun 2015 10:52am |
Ok thanks I will give them a go |
11th Jun 2015 11:27am |
When you consider LR charge around £500 for the same part it's cheap. |
11th Jun 2015 5:15pm |
Unnecessary quote removed
11th Jun 2015 5:18pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
just a note that when you picture it in its doesn't see properly locked in.
11th Jun 2015 6:04pm |
Your on the same wave length as me I've contacted the dealer that sold car originally and he has Told me to contact him tomorrow and he will have a look for me Thanks |
11th Jun 2015 9:43pm |
