![]() | Home > Maintenance & Mods (L322) > Help - Mantec bash plate, cant fit, missing a mounting point |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
Hi All,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
No pictures showing for me...?? Pete
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Show ok for me Pete (when you click on the green linky) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
That is part of the front subframe not the engine main frame at the front. it is just a plate welded on, it won't be available separately. If your having trouble getting someone to do it on the car then take it off and take it to a welding shop and say you want it to look like the other side... Bumper crash bar, and a few other bits off and it unbolts
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It's just a flat plate. Any metal fabricator car knock that up for you in 1/2 hour. Get a bit of cardboard and cut to the same shape as the one you have (ie trace it and cut it out), then offer it up to make sure it fits the other side. The bit of cardboard will be the template for making the new bracket.
Thanks all, Zirconblue, I will be going down that path |
