Home > Maintenance & Mods (L322) > Recommended anit-freeze coolant for 2003 L322 4.4 v8? |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
Folks,
4th Jun 2015 2:56pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
JLR specify
4th Jun 2015 4:32pm |
A picture paints a thousand words....
4th Jun 2015 4:34pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
When I did mine I sed the correct G48 spec which you can buy under the Comma brand from Halfords and a lot of good motor factors. |
4th Jun 2015 4:49pm |
That picture helps. So the float needs to be poking out from cold.
4th Jun 2015 5:18pm |
Found the G48 spec Comma in Halfords and it was green so I went for a pink/red which mine already had in as per the above link I posted.
4th Jun 2015 10:40pm |
It will take over 10mins sat at idle to get up to temp, take it for a 10mile run then come home and lye underneath it...
4th Jun 2015 10:59pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
The correct coolant for the 2002/03 M62 V8 (and TD6) is G48 Ethylene Glycol fluid as Hayland says (usually blue, green or pink).
5th Jun 2015 8:30am |
My system had pink in already so I topped it up with the pink OAT ready mixed. Didn't want to mix with any other colours (green/blue) as they would react. I have no idea what type it was that was already in other than it being pink.
5th Jun 2015 10:46am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
You can try it, if it's only a minor leak it might solve it for a while. It's only a temporary fix though, and over using it just fills the system with rubbish. But saying that it's easy enough to flush out when you eventually repair the system properly
5th Jun 2015 11:42am |
