Home > Maintenance & Mods (L322) > 2003 TD6 full service,what's the best online site to buy pa?
antonio3z
Italy 2003 Range Rover Vogue Td6 Adriatic Blue
Hi mates!
I would like to buy all the parts I need online, and there're many, what's your experience about? need to buy a lot of stuff, as far as understood, here are the following parts I wish to replace in my 162000km FFRR, and it would be nice to buy everthing from a single shop.
-Oil Filter & washer
-Fuel Filter
-Clima Filter
-Engine Breather Filter
-Air Filter
-9L Castrol magnatech fully synthetic
-2L differential oil
-1L transfer box oil
-Wipers
-Xenon lamps
-Front & Rear disks and pads
-both lower front arms each side
-passenger side mirror
Then I wish to replace, brake fluid and cooling system fluid, well if there's anything else missing kindly let me know.
Thanks a lot! cheers,
Antonio
Post #330712 3rd Jun 2015 9:01am
here,
http://www.fullfatrr.com/forum/duckworth-parts-vf24.html
or,here
http://www.fullfatrr.com/forum/advanced-factors-vf37.html ... - .- -.
Post #330713 3rd Jun 2015 9:03am
Zirconblue
I'm pretty sure you'll be better off buying the oils in Italy, because they're heavy and postage will be expensive.
Differential oil is just normal 75w90 GL5 gear oil.
Transfer box oil is a special one, but it's not expensive from a Land-Rover dealer and you only need 1 litre.
You don't really specifically need the Castrol Magnatec for the engine, Mobil 1 or any other premium brand fully synthetic oil of the correct specification will be fine. Look for BMW Longlife on the label.
For all the filters you might be better off buying a Britpart Service kit, it includes all the filters in one box.
When i serviced mine a couple of weeks ago, i shopped around all the suppliers, Paddock, Island4x4, LR Direct, and ordered different parts from all of them, as for the service kit for example some retailers were half the price of others, but more expensive for something else. If you're getting the whole lot posted to Italy though, i can understand why you want to pick one supplier as postage might be your biggest expense.
Post #330729 3rd Jun 2015 10:54am
antonio3z
Mates well thanks a lot for the usefull information!!
Can't wait to put my dirty hands under the hood!!
The guidance is very similar to what I've seen around online, basically there're a couple of big LR parts shop to look for. Many of them are also on ebay and sometime at a better price.
I used to buy oil in gemany on ebay, prices where quite good.
Thanks again for your support. Any help about what has to be checked and replaced is deeply appreciated.
Cheers,
Post #330962 4th Jun 2015 2:54pm
antonio3z
Mates what do you think??
Islelandrovers ebay page:
range rover l322 performance drilled+grooved brake discs and pads terrafirma Q.tą 1GBP 99.99
range rover L322 front suspension arm set with ball joints l322 2002-2012 newQ.tą 1GBP 189.99
Range Rover L322 & Sport + D3 Genuine Osram D2S Xenon Headlight Bulb XBI000030Q.tą 2GBP 40.00
RANGE ROVER TD6 SERVICE KIT RANGE ROVER TD6 FILTER KIT M57 FILTER KIT 2002-2012Q.tą 1GBP 44.99
RANGE ROVER L322 FRONT ANTI ROLL BAR LINKS SET L322 DROP LINKS X2 LR030047 X2Q.tą 1GBP 24.99
range rover l322 supercharged clear side repeaters clear indicators for wing x2Q.tą 1GBP 14.99
Post #331479 8th Jun 2015 9:33am
have you tried duckworths? ... - .- -.
Post #331483 8th Jun 2015 9:48am
antonio3z
Just wrote on their forum page,
Thanks for the advice! Thumbs Up
Post #331487 8th Jun 2015 9:59am
you might also want to consider how much Islelandrovers will charge you to deliver to your country.. ... - .- -.
Post #331491 8th Jun 2015 10:03am
antonio3z
I wrote an e-mail also to them (I guess that islelandrover is the same as Maltings ltd)
If they have averything is going to be a big and heavy box, I suppose that most depends on their agreement with the carrier.
I'll Bow down
Thanks!
Post #331494 8th Jun 2015 10:13am
antonio3z
Not bad advanced factors, all I need and 41 shipment cost to italy!
CRD500190 Mirror Glass LH Convex CRD500190 Mirror Glass LH Convex
Cost
€117.39
LWCB26B LUCAS SINGLE FRONT WIPER BLADE RANGE ROVER L322 02- LWCB26B LUCAS SINGLE FRONT WIPER BLADE RANGE ROVER L322 02-
Cost
€18.80
66240CBI OSRAM XENARC D2S COOL BLUE INTENSE (HID) 66240CBI OSRAM XENARC D2S COOL BLUE INTENSE (HID)
Cost
€150.71
452018 TAILGATE LIFT STRUT 452018 TAILGATE LIFT STRUT
Cost
€36.14
FDL6969 FRONT STABILISER LINK 02- RBM500200 FDL6969 FRONT STABILISER LINK 02- RBM500200
Cost
€42.03
RBJ000130R FRONT LEFT UPPER SUSPENSION ARM 02- RBJ000130 RBJ000130R FRONT LEFT UPPER SUSPENSION ARM 02- RBJ000130
Cost
€58.89
RBJ000120R FRONT RIGHT UPPER SUSPENSION ARM 02- RBJ000120 RBJ000120R FRONT RIGHT UPPER SUSPENSION ARM 02- RBJ000120
Cost
€58.89
RBJ500920R FRONT LOWER SUSPENSION ARM 02- RBJ500920 RBJ500920R FRONT LOWER SUSPENSION ARM 02- RBJ500920
Cost
€87.36
15007E CASTROL SYNTRAX 75W90 FOR MANUAL GEARBOX, TRANSFER BOX & STD DIFFERENTIALS 1LTR 15007E CASTROL SYNTRAX 75W90 FOR MANUAL GEARBOX, TRANSFER BOX & STD DIFFERENTIALS 1LTR
Cost
€41.10
001Y RANGE ROVER L322 3.0 & 4.4 BREMBO FRONT DISC & PAD KIT FOR ATE/BMW SYSTEM 001Y RANGE ROVER L322 3.0 & 4.4 BREMBO FRONT DISC & PAD KIT FOR ATE/BMW SYSTEM
Cost
€164.41
017R FULL SERVICE KIT RANGE ROVER L322 3.0D WITH CASTROL MAGNATEC OIL 017R FULL SERVICE KIT RANGE ROVER L322 3.0D WITH CASTROL MAGNATEC OIL
Cost
€143.86
Your Delivery Country
Sub Total: €766.32
Delivery: €41.10
Vat @ 20%: €153.26
Total: €960.69
Post #331500 8th Jun 2015 10:48am
antonio3z
I'm still lost among online shops! some have very expensive shipment costs others very low but without all the stuff I need.
Post #332330 13th Jun 2015 12:09pm
