Home > Technical (L322) > Winch on TDV8, backspikes to ECU?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
A winch won't create a back spike but it will draw a lot of current, you will have to run new cables to the front and connect to the battery direct, the power to the rear fuse box is not sufficient. if you are using it a lot then fit another battery in the back (see WIKI) and use that one through an isolator to disconnect it from the vehicle when in use, I'd also use a deep cycle battery in the boot as these will last longer with a winch... Pete
28th May 2015 4:18pm |
Ethanicus Member Since: 23 Feb 2015 Location: Surrey Posts: 34 |
On my disco 2 I hard wired an Anderson connector to the battery with an isolator. The connector is in the grill for quick access and then I used a small winched mounted to a tow ball bracket with 5m 25mm2 of cable covered in a tough braid. I use this when i need to pull the car trailer from bottom of the garden on my own.
28th May 2015 4:36pm |
Wofforduk Member Since: 08 Oct 2014 Location: Bromsgrove Posts: 9 |
Cheers both.
28th May 2015 8:47pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
You could always fit a diode in the winch cables .... one way current only then! NW060
28th May 2015 9:31pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
or you could put one of those welding surge protectors across the battery? |
28th May 2015 10:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Have a search around on Alternator issues on the 3.6 TDV8... there’s been a LOT of failures So, make sure your happy putting that much extra stress on it before you go too far sir |
28th May 2015 10:37pm |
Oh Right.... I didnt know about that, having seen the location of the alternator Id rather not bust it!! but then again, we work with the things and are normally pretty bullet proof things.
29th May 2015 2:13pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Why not just sit a very large fully charged battery (or pair) in the boot for the limited number of times you intend to use it.
29th May 2015 5:49pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
It is a decent alternator, 150A if I am not mistaken.
29th May 2015 6:08pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Replacing the alternator on a TDV8 is a pig of a job!
1st Jun 2015 12:44am |
It's not the easiest of jobs, but yes, 2.5 hours |
1st Jun 2015 5:15am |
Winch was never offered by LR on a TDV8 platform was it? There must be reasons as to why it was NOT offered by them? If not due to weight??? |
1st Jun 2015 9:30am |
thats a pretty big alternator! then again i thought it would be as its running a lot of electric stuff.
1st Jun 2015 7:59pm |
If your pulling a three ton trailer up a slipway then you only need a very small winch, these are real cheap and will run off a cigarette lighter socket in the boot and hang on the towbar...
2nd Jun 2015 9:45am |
