![]() | Home > In Car Electronics (L322) > Towing electrics pre-2006 vs. post-2006 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
P.F Jones supply the LR specific 13 pin electrics. Have just fitted them to my 2005 MY FF. John
Also,
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
I got a genuine 13pin kit for y 2003 car from a parts supplier in Belgium, from memory I toyed the part number into Google and found them that way |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
They do, however it seems to use an aftermarket ECU, rather than utilise the proper LR one, which i'd rather keep. |
Just had a quick look to see if I bookmarked where I bought my kit from and I didn't, although I did come across this place http://www.lrspareparts.com/eshop/13-pin-t...-7410.html |
The one they supplied is the same as the one CamTechCraig posted on another thread. It works properly. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
I've just emailed them to confirm what they're selling is the genuine part pictured and not the Britpart/PF Jones aftermarket one. |
I expect they do, but i'd like to try and keep the car using OE parts if possible. I already have the original control unit with the 7 pin electrics. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
The one I got from P F Jones is a Westfalia item
Thanks, i have emailed them to enquire about it, but they haven't replied yet. |
Harness was the same from 02my-09my either in 7 or 13pin guise. The ECU from your existing kit will work on both looms sir ![]() |
I thought it might be, they've obviously just changed the length or colour of something slightly. So it's generated a new part number. Which they listed as 06 onwards! |
Westfalia kit arrived from PF Jones today along with the farmers hitch.
