Home > Maintenance & Mods (L322) > 2006 Vogue 4.2 supercharged replacing steering rack |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
HOW MUCH????
26th May 2015 12:11pm |
Goatboy1972 Member Since: 22 Sep 2011 Location: ESSEX Posts: 26 |
nice that is a help. is that genuine L322 part? |
26th May 2015 12:12pm |
I assume that you have checked all other "play causing" items such as track rod ends and suspension rubbers ?? MY 2010 5.0 SC Galway green and sand interior!!
26th May 2015 12:16pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
As well as the track rod ends that can wear and give play, there is a "rack end" each side that has a nylon bearing and they wear as well, the track rod ends and rack ends are very easy to replace and pretty cheap, if they haven't removed these and checked them then they can't check the rest of the rack, any play in the rack, rack ends or track rod ends will show as play unless you strip it down and check, sounds like they are trying to have you over, not saying the rack isn't worn but it's unusual, it's usually the rack ends or track rods....
26th May 2015 4:53pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2634 |
Was quoted £1800 for one last week , obviously genuine Landrover boxed, zf from euro parts was £729, refurbished are cheaper still with 12 months warranty |
26th May 2015 4:56pm |
So my guy is saying the 829 option is refurbished rack. As for track rods etc yes they are all being replaced but he says there is still excessive play. FWIW I do trust these guys as I have serviced cars with them for years. They wouldn't do the work unless they thought it needed doing. |
27th May 2015 11:01am |
The refurbished one is likely to have started life as the genuine article anyway and also the refurb kits will likely have come from ZF as well, but given how relatively simple they are to refurbish that still sounds like a stack load of money, unless that's the all in fitted price of course. One assumes they are including the cost or re-aligning the thing afterwards as well
27th May 2015 11:16am |
Completely understand but sadly these guys are a second opinion. There are massive flat spots on the tyres that are less than a year old with less than 1k miles on them. This seems to make sense that something is seriously amiss up front.
27th May 2015 11:26am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
One other thing to check is the connection from the lower steering column to the splined shaft on the steering rack. If the nut on the lower column has become loose (even just by a teeny amount), the column doesnt grip the splined shaft tightly and the resultant movement can show up as steering play, i.e. you can turn the steering wheel left and right by a good amount before the wheels turn. I've read threads on this forum before about this, so do a search first.
27th May 2015 11:32am |
