Home > In Car Electronics (L322) > Disconnecting battery
Torretstone
United Kingdom 2003 Range Rover Vogue SE Td6 Barolo Black
Hi I'm of on holiday and worried about flat battery on return to airport would it be ok to disconnect battery for 8 days so I no it will start when I return it's a 2003 td6
Post #329201 23rd May 2015 8:51pm
I can't think of any reason why you couldn't disconnect the battery -ve terminal and re-connect on your return.
You won't have any alarm function though.
On reconnection after starting the car you will need to turn the steering wheel full lock each way.
I assume your battery is ok?
You really shouldn't need to worry about 8 days unless you know of a fault causing a battery drain.
Post #329202 23rd May 2015 8:57pm
...and try your key in the door lock to make sure it works ok as you wont have the remote function. ... - .- -.
Post #329215 23rd May 2015 10:42pm
Not meaning to be a worry wart but, will your insurance company be happy with you doing that? Mine would have some questions if i had to claim... Whistle Rolling Eyes
Post #329222 23rd May 2015 11:24pm
How would they find out ? you can't steal a car with no battery Laughing and if the perps did reconnect it some how and get in the car the are unlikely to fess up aren't they Rolling with laughter 2008 MY Supercharged
Post #329231 24th May 2015 1:39am
The alternative to disconnecting the battery is to leave it connected as normal and buy a smaller battery to sit in the boot which together with a set of jump leads would allow you to start the car should the worst happen.
I've tried a 40AH battery to see if it would work and had no problem, was in summer though not sure about during the winter.
As Stan has pointed out be sure to check that you can open the car manually with the key before you leave it.
Carrying a set of jump leads in the car is quite useful you can usually find someone to let you use their car to jumpstart your own should the worst happen.
You could always try a solar panel as it's summer it might be quite effective. Probably need about 10-15W output.
Post #329237 24th May 2015 6:23am
johnboyairey
I remember taking the kids to see some of the last Concord take offs at Heathrow, the thunderous roar from those engines with blue flame afterburners used to shake the fillings in my teeth, it was absolutely awesome! But laughed at the orchestra of car alarms all chirping from the (parallel to runway) car parks. There were three take offs a day I think. But I bet there is an on hand man with sack truck battery on leads, making a quick buck even today.
Post #329247 24th May 2015 8:30am
Because the OP stated he was going to on an open forum Whistle Whistle Whistle Rolling Eyes
Post #329249 24th May 2015 9:02am
Spare battery or a booster pack has to be a better option - even just a set of jump leads - there will always be someone who will stop if you're standing in a car park with jump leads in your hand.
I keep a set of these in the boot with my spare wheel. Booster pack would be better, but takes up too much space.
Post #329256 24th May 2015 9:23am
Zirconblue
If you're leaving it at one of the decent airport car parking sites they'll be well used to flat batteries and be able to jump it for you should you need it.
Post #329257 24th May 2015 9:28am
