![]() | Home > Technical (L322) > 2012 headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
from memory there should be a sticker on the underside of the light unit..
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Do they have facility to convert them?
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
The levers for touring, don't actually convert the lamps from LH to RH drive. They just operate shutters across the tops of the beams to cut off the bit that would dazzle oncoming motorists.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
mine goes left low to right high on n/s tried 3 bulbs all same |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6761 ![]() ![]() ![]() |
Is this on the car you bought from CTC?
was wondering if it was an adjust or other |
So why not just ask him directly then? Got - 2017 SDV8 Autobiography in Loire Blue
