Home > Technical (L322) > 2012 headlights
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
2012 headlights
the drivers side headlight is fine the glass dome clear but passenger side has a 2 mill ridged line across the centre is this norm as was getting flashed and checked beam and its throwing light up on beam tester as a LHD pattern, wheres the part number to check Confused
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #329141 23rd May 2015 1:33pm
from memory there should be a sticker on the underside of the light unit..
edit, look at this ebay listing, it shows the sticker,
http://www.ebay.co.uk/itm/2010-2012-Land-R...2a513a6cca ... - .- -.
Post #329142 23rd May 2015 1:37pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Do they have facility to convert them?
Remembered reading this recently as I'm looking at a France trip also but need to check if my lights have the levers.
May solve your problem.
http://www.landyzone.co.uk/lz/f10/l322-hea...56937.html 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #329214 23rd May 2015 10:38pm
Zirconblue
The levers for touring, don't actually convert the lamps from LH to RH drive. They just operate shutters across the tops of the beams to cut off the bit that would dazzle oncoming motorists.
If you park a RHD car square in front of a wall and put the headlights on, you'll see the beams have a slope to the tops of them, starts high on the left and goes down to the right.
If you do the same with a LHD car the beam does exactly the opposite.
Flicking the lever on either of them, just makes the tops of the beams flat, they wont dazzle motorists when driving on the wrong side, but they wont light up the kerb side of the road when driving on the correct side either.
It might get you through an MOT by flicking the lever, but you'll just have mediocre headlights all the time as half the beam is missing.
Post #329224 24th May 2015 12:15am
Scottyav
mine goes left low to right high on n/s tried 3 bulbs all same Confused _____________________________________________________
Post #329279 24th May 2015 1:27pm
Is this on the car you bought from CTC?
if so, would you not be better placed approaching him directly (and privately)? Got - 2017 SDV8 Autobiography in Loire Blue
Post #329281 24th May 2015 1:48pm
Scottyav
was wondering if it was an adjust or other Thumbs Up _____________________________________________________
Post #329282 24th May 2015 1:53pm
So why not just ask him directly then? Got - 2017 SDV8 Autobiography in Loire Blue
Post #329287 24th May 2015 3:17pm
