Home > Wheels & Tyres > Powder coating alloy wheels
This is an interesting posting on Freelander 2 regarding the refinishing of alloy wheels by way of powder coating as opposed to painting.
Never seen this comment before but I think it would put me off powder coating if the need for refurbishment arose.
http://www.freel2.com/forum/post264123.html#264123
Post #328515 18th May 2015 8:20pm
Zirconblue
While alloys are generally spray painted, i think they're all given a powder coat primer (the grey stuff you see on the back of them) even when new.
Although it might raise the question how many times this could be done?
Post #328518 18th May 2015 8:24pm
mzplcg
Powder coating looks poo as well, like overly thick paint. I would never consider it, only spray paint. Even some places heat cure paint though which isn't a good idea, normally the ones who turn it round in a day. Letting paint dry without accelerating the process with heat takes time, normally at least 48 hours before it's hard enough to refit the tyre.
Post #328562 19th May 2015 7:18am
Zirconblue
Also everyone raves about powder coat on everything, but from what i've seen it's hard wearing when new, but as soon as there is a break in the coating and you get corrosion under it the stuff comes off in sheets. Unlike traditional paint where it blisters in places.
Post #328566 19th May 2015 7:50am
There are “pro’s & con’s" with both!
Post #328573 19th May 2015 8:23am
Zirconblue
Exactly, but all you seem to hear about in the classic car community, is powder coat, powder coat, powder coat on everything.
Post #328602 19th May 2015 12:12pm
mzplcg
Makes a change from my classic motorcycle days though. They were all nuts about stove enamel.
Post #328605 19th May 2015 12:26pm
supershuttle
So I might just give mine a quick rub down and spray 'em Silver - or whatever colour I fancy come to that Very Happy Geoff
Post #328622 19th May 2015 2:57pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
I had my mach 5 wheels powder coated in white when i ordered them, they cracked as soon as i did the wheel nuts up. I sent them back and he re did them, but still they cracked, then as they were steel after only a few moths they started to rust.
Not impressed.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #328636 19th May 2015 3:58pm
Well that quote is interesting but it doesn't apply to wheels fitted to the FF, none of them are forged, they are all cast wheels and are not head treated, even if they were the 200deg C that they are taken to is nowhere near the 300 - 400deg C it takes to anneal aluminium.
Paint or powder coat.... as with everything it is down to preparation, if aluminium or steel is powder coated without treating the surface and pre heating the part before coating then it will flake off, if you paint bare aluminium or steel without using an etch primer then it will flake off...
A good quality powder coat will look exactly the same as a well painted wheel, most refurb places put too much powder on to cover minor imperfections...
As with most things, you get what you pay for, cheap powder coating will last about as long as cheap painting...
Any powder coated or painted wheel should have the coating removed from the bolt mating surfaces and the center of the wheel before they are fitted, you can't torque them up with paint or powder coat under them... Pete
Post #328643 19th May 2015 4:18pm
steptoe
Rubbish. The post above hits the nail on the head.
If they're powder coated by someone who works to quality and not price you won't have any problems.
And you must have the complete wheel coated, not just the fronts and an inch into the rim.
My wheels, powder coated. Still as good as the day they were done
Post #331309 6th Jun 2015 5:31pm
johnboyairey
as for the paint option, yes modern 2 pack paint has to be heat dried, to get the catalyst to finish. otherwise you get a soft dull finish.
clearcoat on cars has to be baked. you can see when it hasnt been baked or infra light cured.
i like paint. but i have seen a very nice looking chrome look powder coat. to old steel wheels. you really have to look twice. and only £55 a corner.
Post #331316 6th Jun 2015 5:48pm
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Steptoe
Would love to see a pic of those wheels on your motor Thumbs Up
Post #331360 7th Jun 2015 6:58am
