![]() | Home > Technical (L322) > How does the FFRR calculate fuel consumption? |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
cant answer your question directly but the consumption figures for LPG are very similar to Diesel , so in real terms it wont change that much , its just the big price difference that makes people say its twice the mpg, its not, its just half the price.
Merf Member Since: 01 May 2015 Location: Yorkshire Posts: 6 ![]() ![]() |
That is what confuses me.
how does the LPG get into the engine? through the original injectors or is it fed in to the fuel system before that . I guess if you reset your mpg reading and you start getting similar looking numbers to petrol then the system is now reading the lpg , as I said , its similar to petrol ( not diesel as I prev said) the point of measue must but at a point after lpg gets into your fuel system |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
The car still thinks its running on petrol as the counts the duty cycle of the petrol injectors - that's how it calculates the MPG Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
The engine management ECU calculates how long it needs to open each injector to get the desired (calculated or actually taken from a pre-programmed table) amount of fuel into the combustion chamber. It uses sensor information in combination with the table (multi dimensional) to determine how much fuel is needed to get the optimum mixture (amount of air going in from the MAF, air temperature (i.e. density), Lambda sensor data (mixture too rich or too lean or just right), etc.).
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
ebajema, that was exactly my understanding and the reason I cannot understand people who say the trip computer mpg calculation in not accurate - it simply has to be! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
I thought that an LPG installation uses its own injectors that are drilled and tapped into the inlet manifold, I also thought that the installation had its own ECU that is a stand alone system from the main cars system
Graeme, I don't understand either why it is not more accurate but according to my friend it isn't. MY 2010 5.0 SC Galway green and sand interior!!
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I expect it's accurate with regards to the amount of fuel used, but may be less accurate with regards to the distance travelled.
Any error in the calculation of distance by the vehicle would be present in both the computer calculation and any manual fuel used divided by distance travelled calculation.
Unless you use a portable GPS to measure the distance travelled (as some do, when they do the full tank/drive/full tank method) |
