![]() | Home > Maintenance & Mods (L322) > Problem with gear box zf 5hp24 or tc |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
That twin row angular contact ball bearing is only used in the RWD versions of the 5HP24 where it is required to take the plunge loads from the propshaft.
pjpetit Member Since: 23 Jun 2014 Location: vernon Posts: 17 ![]() ![]() ![]() |
Ok phil
You will see that the model number on the green plate is 1058 000 032
Thanks you rrphil
The component that looks like a large bearing in the centre of the stator is actually a one-way clutch (or mechanical diode) that only allows the stator to turn in one direction.
Thanks you for explanation
on vue it's the 32330 disc carrier
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Just a thought.... could it be worn out clutch plates on first / second gear? Only from what I can gather it's all OK in 3,4,and 5..... Shorely if it was a bearing then it would whine all the time? Yesterday I couldn't spell Engineer... Today I are one!
Ok understood
That looks like the inside of the E-clutch hub and you certainly wouldn’t expect to see scoring in there.
Hello i have double check the steel plates and friction
Hello
hello
