Home > Maintenance & Mods (L322) > Front door |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
http://www.fullfatrr.com/forum/topic31582.html
15th May 2015 8:10am |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
If your door is jammed in superlock, you have exactly one chance to get at it:
15th May 2015 8:55am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
👏Top advice 👌 2008 MY Supercharged
15th May 2015 10:32am |
mudknight Member Since: 21 Sep 2012 Location: birmingham Posts: 73 |
Brilliant ,, I will try that when I'm home , thanks so much , will let you know how I get on 👍 |
15th May 2015 12:01pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
Absolutely brilliant information!
15th May 2015 12:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35273 |
great stuff, wiki'fied... ... - .- -.
15th May 2015 12:27pm |
Great post - just had a look on mine, it will be hard to get at with the rear door in place but certainly possible with patience! |
15th May 2015 12:41pm |
I am working on the car now as said in pics ect , the "Allen bolt " already moves down when pulling on the outside handle , do I need to push it further than it already goes ?? |
16th May 2015 9:50am |
yes, that should open the lock.
16th May 2015 1:57pm |
I've finally done it ,, the way you described only opens the door if the outside handle cable is broke , the way to open the lock when it's locked is to go in from the top , pull the door card away at the top far as you can , window up or down makes no difference , remove air bag , pull away inner foam protection stuff , get a screw driver and hammer , knock through the plastic on the top of the lock , it exposes the lever which you need to push down to unlock the car , you then can only open the door from inside ,,
16th May 2015 2:06pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
I know that it's an old thread, and wiki'fied, but thought I would give my thanks to this brilliant forum for helping me out.
11th Nov 2016 8:17pm |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
I believe I have the same problem as outlined on this post although my car is a 2010 MY and the part number is different (I think the current part number is LR019759 not LR013378 as above)
3rd Apr 2018 3:14pm |
Has anyone done this on a 2010 on car? Have ordered the lock from Dan, just waiting for it to arrive
9th Apr 2018 7:55am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
So Today I managed to do this by not destroying the Door Card.
14th Aug 2018 2:49pm |
