Home > Maintenance & Mods (L322) > Problem with gear box zf 5hp24 or tc |
pjpetit Member Since: 23 Jun 2014 Location: vernon Posts: 17 |
Ok nobody to help me |
8th May 2015 10:30pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
its difficult to understand your problem? your gearbox sounds like a bird ? I don't understand your photos either |
8th May 2015 10:51pm |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
My thoughts exactly Viper 😁 2004 RR 4.4 V8 Autobiography |
9th May 2015 9:49am |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
Pierre-Jean
9th May 2015 11:15am |
Bonjour ok
11th May 2015 3:34pm |
This is a slightly “loose” translation as parts of the source text are a little ambiguous …
11th May 2015 4:13pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
could be the output bearing on the gearbox, if the prop shaft was slightly out of balance it would kill the bearing gradually. It might well be that it's just a co-incidence that it happened after the oil change. |
11th May 2015 4:51pm |
Is it easy to change? |
11th May 2015 9:22pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
The transmission doesn’t have an ‘output bearing’ as such (other than a small needle roller ‘steady’ bearing in the F-brake drum) because there’s a transfer box between it and the propshaft.
12th May 2015 10:16am |
Aren't there bearings on the transfer box where the outputs go to the prop shafts?
12th May 2015 10:54am |
YES
12th May 2015 1:05pm |
There is no ball bearing on the transmission output - you must be looking at a diagram of a RWD version of the 5HP24 and not the 4WD version.
12th May 2015 3:19pm |
Isn't this just semantics? He said bearing not "ball" bearing? Bearing covers ball bearings, roller bearings (both straight and tapered) even white metal in the case of an engine. |
12th May 2015 7:41pm |
Sorry but i speak about this bearing g park lock and output rep 690
12th May 2015 8:55pm |
