Home > Wheels & Tyres > TPM system.........again
Page 3 of 3 <123
mzplcg
Ah, sí señor, que uno definitivamente hacer lo que usted necesite. Thumbs Up
Post #326077 5th May 2015 12:16pm
elmer
2008 Range Rover Vogue TDV8 Java Black
Hello everybody and thank you for yours advices,
Finally,I´ve bought a IIDTool DA6412 bluetooth of Britpart. I´ve bought in LR centre Sales.Price is (totally) GBP 420.
This is the cost for not seeing more the tpms warnings!!!! The official dealer in Barcelona failed to fix the problem(Four times in 3 years) and refused to cancel the system
When I have the IIDtool , I will tell you as it works.By the way, I think using it for more things,ja,ja,ja.
Best regards!!!!
elmer
Post #326133 5th May 2015 5:32pm
Post #326166 5th May 2015 8:15pm
elmer
Hello,
I have my IIDtoll bt DA6412
I want cancel/dissabled TPMS warning (light and board).¿Do I have to use CAR CONFIG menu and then i´ve chosse (what option?) , or do I have to use other menu?
I will be eternally grateful to you if you can help me with this
Thank you very much
elmer
Post #327434 12th May 2015 2:48pm
Andy B
Hi Elmer, it is the CCF you have to alter, I think it is in the BCM Body Control module (ie ECU). SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #327441 12th May 2015 3:14pm
elmer
Hello,
Finally,I solve the bloody TPMS warnings, ¡¡¡ Very Happy !!!
When I connected IIDtool for first time,I did well the work for cancel it but below you can see the reply of the GAP guys
The TPMS deactivation is done in 2 steps:
-Disable the TPMS in the CCF: IIDTool Menu->Car Config->Tire Pressure Monitor System set to Tire pressure monitor system is not fitted
-Remove FUSE 16P from the central junction box (glove compartment)
I hope I have solved the problem.I will tell you.
Thanks everyone for your help
elmer
[/b]
Post #327463 12th May 2015 4:41pm
dbarr1980
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I seem to be having same problems, think I'll just get system turned off aswell
Post #329186 23rd May 2015 7:50pm
elmer
Finally,I solved TPMS problems with IIDtool and now,you could not imagine how happy I am, without seeing the light and the warning message every day Very Happy
Post #329204 23rd May 2015 9:11pm
Page 3 of 3 <123
