Home > Maintenance & Mods (L322) > Help with rounded locking wheel nut
Page 3 of 3 <123
Laughing Laughing Laughing Bow down Thumbs Up
Post #327298 11th May 2015 11:16pm
johnboyairey
for people that still have a mangled locking bolt on their wheel, i had the same problem on a merc i have. both fronts were overtightened etc. after the locknut tool failed to work, and i was left with badly chewed bolts (or maybe in your case above, with hardened spinning tops,) i had to resort to electric powertools. namely a black and decker powerfile. which is a small belt sander to bodyshop guys...
i cut from some very thin tin can, a strip of metal wound into a tube, to slide into the gap between the nut and wheel (extending out 10mm) to protect the paint, and firstly with a hardened drill bit i tried unsuccesfullly to get a start hole, but quickly got out a powerfile, and modified it with a long nut and bolt to the end of the 'finger' (sideways) to aid holding it steady with some mole grips, and gently offered the belt tip to he bolt, yes at first it tries to fly off, and the tin tube stops it a little, but protects your rim, and by twisting the file a quarter turn, back and forth, you can grind away a dish shape which you gradually file away down the shaft of the bolt. After around 15 mins of this, and maybe ten belts (from screwfix) later, you will have either given yourself a better chance with a nut removal tool, or removed enough of the bolt to enable the wheel to come off, and the bolt remnants to easily unscrew, and be throw away, -with considerable force! lots of sparks from the powerfile with this, so eye protection, and maybe some masking of wheel too.
Post #327326 12th May 2015 7:34am
Reading through this it strikes me that anyone with locking wheel nuts who wishes to keep them should be getting them all undone, copper greasing the wheel stud and refitting the locking wheel nut to a "reasonable" hand tool tightness only.
Then a couple of times a year loosening the respective nuts and re-tightening them. At the slightest sign of the locking wheel nut becoming damaged it should be replaced with new.
Post #327332 12th May 2015 8:03am
johnboyairey
I don't know that wheels ever get stolen these days anyway, -must be price of bricks! How the world has changed!
Post #327353 12th May 2015 9:04am
miggit
They were only saying on the local news the other night that is an acute shortage of Bricks in the region, and with the demise of the milkman, there must also be a shortage of milk crates. But I wouldn't like to rate your chances of getting a ffrr to balance on 4 milk crates anyway, maybe the Tea leaves have worked out the maximum loading for a milk crate and the ffrr exceeds this. I bet they are scared of falling foul of the HSE, there aren't any load ratings on milk crates Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #327579 12th May 2015 9:39pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
supershuttle wrote:
So I don't often recommend or endorse people on the forum but I have to say that Steve www.thewheelnutman.co.uk was both professional, determined and ultimately successful at getting my Locking Nut off - without damaging the wheel. Bow down
I found this thread, and this recommendation from 9 years ago, when my locking wheel nut got damaged and I searched the forum.
It's a good recommendation! After a 115 mile trip, my locking wheel nut was removed in under 5 minutes. So I'm very happy to add another recommendation.
Post #701029 28th Sep 2024 6:09pm
Page 3 of 3 <123
