Home > Technical (L322) > What size hub nut |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Why do you need to remove the hub nut? rear disc is held in place by an allen screw in the disc face. This will release the disc/drum and give access to the springs and handbrake cable assembly at the top of the hub. .
10th May 2015 2:01pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
10th May 2015 2:21pm |
Must of had a brain fart . ... I blame me been on nightshift last night !
10th May 2015 3:48pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Need to release the hub nut, remove hub to renew brake backplate believe it or not!!! Lot of work for a posy bit of tin!!! |
10th May 2015 4:06pm |
Do you Craig, didn't look like it from what I was look at it earlier
10th May 2015 4:31pm |
The backplate is a solid round unit that bolts/fixes in such a way you need to remove lots to fit WD! |
10th May 2015 4:40pm |
10th May 2015 4:57pm |
Too much work involved in changing the backplate, have a read here |
10th May 2015 5:25pm |
^^^ for fixing/sorting the holes ( I just used some washers)
10th May 2015 6:44pm |
Mrs WD is bring some of them springs home from work later that are used on there cars to see if they do the job.
11th May 2015 4:15pm |
