![]() | Home > Maintenance & Mods (L322) > US-style front indicator unit for 2002 |
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
Hi there,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
The only problem that I can see is the NAS spec lights not only have the amber strip in them but they are illuminated, that in its' self is not a problem as you just don't connect them. However the indicator lamp also doubles up as a cruise lamp, and will have a double filament bulb in it, like a stop and tail lamp, so your wiring loom will not plug in to the new indicator lamp socket. As to whether the bulb holders are interchangeable or not I don't know, if they are then it will be an easy swop, but if they are not then you'll have a bit of a head ache finding the right plug and changing the loom.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
Paul, the NAS side marker front and rear is a single filament 5w capless w5w bulb not a dual filament one |
Rear view of NAS spec Light. XBD 000023
LOOK
They do on a D4, a Peugeot Partner & others in the JLR group Miggit... They use the double filament bulb in lots of cars in the UK sir |
Yes but that holder takes a round bottom bulb Miggit not a square one sir |
That |
Looks the same holder as on my lawnmower headlight Miggit... |
