Home > Maintenance & Mods (L405) > Changing L405 Grills / Fins - easy DIY job
I swapped mine over today - easy job Thumbs Up
I had Atlas & went to colour coded, but I guess just as many people will go the other way.
Mine came from Khan on eBay - I made them a cheeky offer & secured a Santorini Black set for just over �100. They fix to the car using 8 pop fasteners & 2 strips of sticky tape. As they were used, I needed to replace the adhesive tape - which is quite thick, wo ended up using 3 layers of this on both the front & back edges, so �20 worth of adhesive Shocked
Here's what the panel looks like -
and you run a strip of adhesive up the left & with edge - it's obvious when you have it in front of you.
The bottom has a slight lip that sits inside the Atlas coloured moulding on the door -
Removal was easy (though I broke a few of the pop connectors on the first one) - I used a filler knife & screwdriver wrapped in a rag, started top rear & just prised off.
The whole job took 10 minutes Thumbs Up
I had enough of the pop connector thingies from the ones I'd bought and the ones I took off the car to put the new ones on & have some spare.
I fear the new ones are better stuck than the originals, but as I don't plan to change them again any time soon, that's fine with me.
[Edited to add the part number for the clips]
Should anyone need the clips -
https://www.fullfatrr.com/forum/topic57794.html
Post #326948 9th May 2015 8:01pm
looks much better Alistair, thank you for the 'how to'.. ... - .- -.
Post #326950 9th May 2015 8:17pm
Marmite - there will be just as many who prefer the silver.
Colour coded is the default - Atlas costs extra - so every one that you see, someone has paid money for.......
Post #326952 9th May 2015 8:25pm
you have the honour of the first L405 how to in the wiki.. Thumbs Up ... - .- -.
Post #326960 9th May 2015 9:15pm
Very Happy Thumbs Up
Post #326962 9th May 2015 9:55pm
V Nice sir... Like it both ways Thumbs Up
Post #326963 9th May 2015 10:17pm
RR2008HSE
Ditto. Both nice.
Post #326976 10th May 2015 12:20am
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
They both look very nice, I really want to put the autobiography black gills on with color coding to the car. Just the little chrome accents down the fins I think this is a nice subtle way of showing the gill lines on the doors.
However the autobiography gills are very pricey . Around $1500 dollars.
Thankyou for sharing your how to do job info.
Post #326979 10th May 2015 12:54am
362bkr
And it's a yes from me Very Happy
Post #326992 10th May 2015 8:10am
J600.COM
thumbs up from me, looks awesome Thumbs Up
Post #327082 10th May 2015 8:50pm
Lawnman
United Kingdom 2017 Range Rover Autobiography TDV6 Barolo Black
Looks great and thank you for the detail of how to change them, I am hoping you will know the answer to this. Just purchased Sep 14 Vogue with no Fog Lights is it possible to retro fit them. Thank you in advance Thumbs Up
Post #327217 11th May 2015 5:14pm
d3rm0
I would like to do the same plus the front grill but as you said $$$$$$$ for a bit of plastic Censored
Post #327243 11th May 2015 7:51pm
I'm sure it's possible, but I have no idea how & doubt it's easy.....
For a start, does your instrument stalk in the car have a front fog light on it ?
Post #327249 11th May 2015 8:38pm
Lawnman
Hi Alistair, I will have a look, never thought of that Bow down thank you for coming back to me
Post #327252 11th May 2015 8:51pm
wealy
Is it easy to change the strip along the bottom of the door?
It doesn't look right in silver?
Post #378996 23rd Mar 2016 7:53am
