![]() | Home > In Car Electronics (L322) > Current information for AUX input on a 2002 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
There's a BMW kit that gives you everything to create an Aux In in the boot by the TV module.
Actually - thinking back - I think I had to replace the radio module from a BM53 to a BM54 as well - so might not be that straight forward.... |
Shogo Member Since: 01 Jan 2015 Location: Sweden Posts: 61 ![]() ![]() ![]() |
That input is Mono only sadly..would have been a nice solution otherwise.
Yes.. exaclty.. the stock aux is for newer HU´s only ![]() |
Yep - here's where I got the info from.
I simply use one of these plugged into the redundant tape player, works really well for music although I have been described as tone deaf. |
nooo !!!
The Sony one isn't horrible, it works really well. |
I´ve used them.. you get a very high amount of noise and "hum" and compressed dynamics, worse than radio in many cases.
I shall bow to your superior knowledge in these matters and look forward to seeing your ideas. |
Ovaltine Member Since: 24 Mar 2015 Location: Ohio Posts: 4 ![]() ![]() ![]() |
I use the Grom aux input adapter and it works very well. Installation was easy - it takes the place of the CD changer input. I went with the cheaper non-bluetooth version. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3245 ![]() ![]() ![]() |
Does your RR have the touch screen? On their website Grom say that the interface covers 1999 to 2005. They quote their model SKU: RVRU3 as being suitable for the 2005 Range Rover. I wonder if the different market specs come into play?
Mine is a 2004. It has the navigation screen, although it is not a touchscreen. One must use the buttons to move through the menus instead of actually touching the screen.
Thanks for the reply. Will have to look further into it. |
