Home > Technical (L322) > door lock problem after atempting to remove handle |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
i'm sure someone else had a similar problem and the craig-meister said something like put a screwdriver in the lock to click the latch down/up...
6th May 2015 1:52pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
had a look at that post Stan but the door opens fine from inside and out its the locking thats the issue
6th May 2015 3:51pm |
Worth a try
6th May 2015 4:16pm |
could someone check if your car does this when you try to lock it with the drivers door open. I'm now beginning to think it might be a safety thing so you don't lock the keys inside. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
6th May 2015 5:22pm |
Anyone ? I'm a just a bit worried about shutting and locking the car until I know if this is right or not. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
7th May 2015 9:16am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
Just checked for you.
7th May 2015 9:30am |
Thanks for that. Sounds the same as what mines is doing I suppose that must just be the way it is. Did you watch the video I posted ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
7th May 2015 9:53am |
I hadn't but I have now. That is exactly what mine in doing if I lock the doors with the drivers door open. As I say I then locked it with the drivers door closed and everything worked as it should. To date I've not had any trouble with the doors locking so reckon the bouncing lock button is normal for whatever reason. |
7th May 2015 10:02am |
