Home > Maintenance & Mods (L322) > ticking noise behind dashboard |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Had the same thing some time ago... It turned out to be a parking ticked inside the heater motor... I removed the final stage resistor to have a look inside the heater motor.. I was able to remove the parking ticket from there..
4th May 2015 8:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
The big black electrics box in the engine bay is ventilated into the cabin area behind the dash area.
4th May 2015 8:11am |
Does the sound increase / decrease when you manually adjust the fan? 2002 L322 V8 |
4th May 2015 8:31am |
tevista Member Since: 20 Sep 2014 Location: paisley Posts: 16 |
No , its only when u unlock the car and wake it up . Lasts bout 20 secs then all quiet . |
4th May 2015 8:19pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1256 |
Had exactly the same thing recently. Turned out it was a broken blade on one of the fans in the heating / ventilation system under the dash.
4th May 2015 8:31pm |
It was the motor for the footwell blend motor. It was turning further than the flap was able to, it could not be recalibrate do and was replaced.
5th May 2015 7:59am |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
Sometimes my car also does some noises when I turn the key.
5th May 2015 6:34pm |
