Home > Maintenance & Mods (L322) > ticking noise behind dashboard
tevista
Scotland 2003 Range Rover HSE Td6 Zermatt Silver
when I unlock the RR , for the first 20 seconds theres a ticking noise (more like galloping horses ) from behind the centre air vents - any ideas gents ?
Post #325902 4th May 2015 8:32am
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Had the same thing some time ago... It turned out to be a parking ticked inside the heater motor... I removed the final stage resistor to have a look inside the heater motor.. I was able to remove the parking ticket from there..
Have a look here: http://www.fullfatrr.com/forum/topic14961-45.html 2002 L322 V8
Post #325906 4th May 2015 9:02am
The big black electrics box in the engine bay is ventilated into the cabin area behind the dash area.
What you can probably hear is the fan running that provides the airflow.
I think you can quieten it by stripping out the bits in the box and then lubricating the fan shaft.
Not worth the hassle imo, most cars seem to have this noise on un-locking.
Post #325907 4th May 2015 9:11am
pietertje
Does the sound increase / decrease when you manually adjust the fan? 2002 L322 V8
Post #325909 4th May 2015 9:31am
tevista
No , its only when u unlock the car and wake it up . Lasts bout 20 secs then all quiet .
Post #326008 4th May 2015 9:19pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Had exactly the same thing recently. Turned out it was a broken blade on one of the fans in the heating / ventilation system under the dash.
I'll check tomorrow exactly what is was.
Post #326012 4th May 2015 9:31pm
PaulTyrer
It was the motor for the footwell blend motor. It was turning further than the flap was able to, it could not be recalibrate do and was replaced.
Cost �30.53 for the motor and �110 to investigate it!
Post #326051 5th May 2015 8:59am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Sometimes my car also does some noises when I turn the key.
My mec told me it was the EGR self cleaning feature. It seems like a tchk tchk tchk
Could be????? Confused
Besides that, there is also a constant tic, very light, tic tic tic going on.
that one is connected to the rev counter. the needle may be loose or with the teeth messed up, as most of the times the rev counter is crazy, It can mark 0 as it can mark 1500 on idle.
Post #326156 5th May 2015 7:34pm
