Home > Maintenance & Mods (L322) > Electric window problem |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3788 |
There's been some attempt to help me on this but to no avail. Situation is when button is pressed and held it drops a few inches and stops to get it fully open takes a few presses, the same when closing. If the button is "dabbed" to use the auto open and close features it still stops in the same places - is there a reset procedure? Geoff |
1st May 2015 4:32pm |
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 |
Hi there, I had a similar problem to this.
1st May 2015 4:59pm |
Sadly the reset procedure didn't do it, the window travels for a short while then stops, pressing the button again doesn't do anything, keeping it pressed doesn't do anything either. I generally have to wait a few seconds then press again but not always. I can always get it fully shut or fully open but either requires multiple releasing and repressing the switch, I think 4 or 5 times before it is fully open or closed.
3rd May 2015 3:02pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
I'm with mechanism as well, if it has too much resistance it will trip out for a while, sounds like that's whats doing it, try helping it up or down with your hand and see if it will do it then, if it does work then it needs a stripdown to see what's what..... Pete
3rd May 2015 3:17pm |
I did try a helping hand both up and/or down didn't make any difference. Geoff |
3rd May 2015 4:19pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Tried a battery reset Geoff? |
3rd May 2015 4:20pm |
Craig, you read my mind, but Ill have to do it when SWMBO is out as she doesn't like me messing about with the car on the drive. She even came out to ask me what I was doing this morning when I was winding the window up and down Geoff |
3rd May 2015 4:31pm |
Battery reset failed to cure problem, also ran the routine on the ID tool for both a complete vehicle reset and new battery all with no success. The windows seems to move freely enough but just stops several times - all in the wrong place! Geoff |
4th May 2015 12:45pm |
Window ECU - where does it live? Geoff |
4th May 2015 1:00pm |
Looks like it's built in with the Drivers Door Module or part 11
4th May 2015 2:12pm |
Cheers Pete,
4th May 2015 3:21pm |
