Home > Technical (L322) > Water leaking into the cabin, right B-pillar
Shogo
Sweden 2002 Range Rover HSE 4.4 V8 Java Black
Hello
I´ve got some water leaking into the cabin after I was the car. It actually sometimes drip from the right B-pillar down on the floor.
any ideas ?
Post #324581 26th Apr 2015 8:18pm
door seal? ... - .- -.
Post #324583 26th Apr 2015 8:22pm
Shogo
the door seal is fine. acctually seems to come from the seem between the inside roof and the B-pillar trim.
Are the "runoffs" from the glass roof in that neighbourhood ?
Post #324584 26th Apr 2015 8:27pm
i think they might be .. ... - .- -.
Post #324585 26th Apr 2015 8:43pm
Zirconblue
Sunroof drains blocked?
Post #324603 27th Apr 2015 6:18am
steptoe
Windscreen not sealed properly ? .
Post #324620 27th Apr 2015 11:05am
^^it will be one of those 2, has it had a replacement screen at any point? should say land rover pilkington, anything else is a replacement. If it has just started doing it then my money is on the sunroof, as the screens tend to leak from day 1 they are fitted and if they don't then its unusual for them to develop a leak over time Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #324646 27th Apr 2015 5:15pm
Shogo
Thanks for the ideas !..
I´m going to do some more checks.
I´m on an ultra slow connection right now and unable to download rave, anyone who have the instructions on how to remove the right side B-pillar trim ?
Post #324647 27th Apr 2015 5:36pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Mine had the same problem and when I climbed up to look at the sun roof the offside drain was blocked. No amount of poking around with a piece of wire would free it so I crawled underneath. It turns out the air reservoir (I'm assuming it was for the suspension) was stopping the little rubber discharge valve from the roof drain working properly. I loosened the brackets and moved it slightly and got a face full of stinking water for my pains but the problems now cured.
Post #324785 28th Apr 2015 1:01pm
